Top word is Защитнику, reads as Zashchitniku, which means protector/defender. Bottom word Спецназовские , reads as Spetsnazovskiye , and means special forces (I think). So what you have is Russian Military watch
I would really like to have pictures of the movement but the gentleman that owned the watch would not let me open it up. It is a  mechanical watch not a quartz.
JBerry, thanks for the translation that helps me out.
So I wonder if this is an issued watch or just something you can buy as an aftermarket for bragging rights.
Obviously I cannot vouch for its authenticity, but in my limited experience, these watches tend to be conversation pieces rather than ex military. I did find another example in new condition which had been offered for sale on ebay by a US seller in "new unworn condition" which suggests that they might be a retail item rather than special issue.
According to that listing, the text reads as follows....
On the top of the rim: ЗАЩИТНИКУ - to a defender
On the bottom of the rim: ОТЕЧЕСТВА - of the Fatherland
On the dial plate: Спецназовские - of (or belonging to) Special Forces
You never know if it is genuine, I guess it might be.
I do know that HMT produced civilian and armed forces versions of various models of their watches, for example the "Jawan" (soldier in Hindi) which differed simply in the fact that the armed forces versions had a broad arrow on the dial and/or case back. The mechanism being identical to their various other versions. Needless to say, backstreet aftermarket Indian dial re-painters tend to add the dial arrow and/or inscribe the case back with an arrow (sometimes very crudely) as it supposedly increases the "rarity value".
I also know that Fortis produced watches for the Russian Cosmonauts, and also civilian versions of the same watch, so these things are generally a little bit of both additional credibility and marketing gimmick. Fortis watches are generally well made, but like most watches, rely in the main on high end versions of standard movements.
What it all boils down to is, can you research a connection between that watch, and the Russian special forces. If not, then the watch is purely about bragging rights. Even if you can connect the two, the watch, like any other is worth precisely what you are willing to pay for it, not a penny more and not a penny less.
Edited by AndyHull
One thing for sure, no Grunt ever wore it in the field. The case doesn't remotely resemble anything put out by vostok, which it is apparently trying to imitate.My guess? Chinese Knock off trying very hard to convince you it's something it isnt.
I'm pretty certain that no Russian watches were ever issued to their armed forces, or any watches for that matter.
Vostok were the appointed supplier I think, but they were supplied to their equivalent of the NAAFI to be purchased privately.
So it is not an issued watch.
Other nations also adopted this policy, Portugal (Berlan), India (HMT) etc
    • By the way, I opened my watch, looked under a magnifying glass, there is simply no grease, the screws are without traces, the slots are intact.I think it's just a matter of maintenance.there are no rotor marks on the body. And to remove the strap from yours, just press on the 1st side,and slightly move the strap, then on the other side and it will come off.
    • Hi My name is Chris. Just started trying to learn about watch and clock repair as a result of repairing my fathers old 1890s police station clock (about a year ago). The clock was Ok, but having graduated to pocket watches and then wrist watches, despite the really excellent stuff on Youtube, I am struggling a bit.  As a retired engineer, I find the engineering exquisite, but a bit on the fiddly side.  I have done a few practice watches with a little success but failed a few, but have had success with Seiko 7005s, 7009s etc, but have just attempted a citizen 5430.  Nightmare.  My wife thought I had found religion as I spent so much time on my knees with my eyes to the floor looking for springs.  Got through that and found that the balance is shot.  Trying to source one or something that will fit from the citizen range has me totally perplexed.  Tried Ebay, Cousins etc without luck.  Any advice as to alternatives that will fit or alternative sources would be gratefully received.
    • I have only been a member for six years & I have found this a very friendly forum although I don’t have anything to do with watches not because I don’t like watches but because I have gout in both hands so my dexterity isn’t very good, I restore torsion clocks & occasionally other antique clocks also at 72 my eyes are not what they used to be, that is why I only post on the clock forum & the lathe forum mostly . As others have said Mark it is much appreciated that  you are willing & able to do this. very many Thanks Dell
    • Ah, this is brilliant, thank you very much!
