The five star admiral Longines, looks genuine, original hands, dial. Good brand.
Evidence of moisture inside the case therefore the movement. I would remove the back, peak inside, send picture and test the set mech, winder.
Moisture damage to the dial, greately reduces the value. Aprox $350
The vulcain, dial is looks suspecious, examine close see if painted, see if the word swiss appear at six oclock. $30
Tissot, check the extend of water and other damges inside, $25
Seiko chrono aprox $150
Between the two of us, take ths GUB home, very liitle work. Best of the herd. Don,t know a price.
The Russian one, just that its chrono. Values not much.
My appraisal is usually ignored.
All of these watches are mine. I'm just waiting on them to be shipped. Plus alot of seikos as well.
Sent from my SM-G965U using Tapatalk
Enjoy em in good health, I would post a query for advice on how to the longine dial, or have it cleaned.Unless experienced you shouldn,t attack the dial.
Best wishes.
the reliance will likely have a seiko movement akin to the 66..The ones I have seen were sold by croton as their budget line, something like a caravelle by bulova.
Edited by yankeedog
content
the reliance will likely have a seiko movement.The ones I have seen were sold by croton as their budget line, something like a caravelle by bulova.
Do you know what movement the admiral 5 star is expected to have?
I thought NuceJoe would say the caseing on this one is unique he usually has a sharp eye, I haven't seen it before since the most of these came with an 18k gold case.
Depending on what year the watch was produced it came with a range of different movements, here is a selection..
calibre 340
calibre 501
calibre 506
calibre 507
calibre 508
calibre L 636.5
calibre 1753
calibre 6651
Since your watch looks like a 70's piece I would guess it should have a calibre 50X inside, but this is a tricky one..
I don,t know the caliber, but think its an in-house longine make. Pic of min only date. Not solid gold.
Sorry for the late response guys.
Regards
Yes there was some monocoque cases too , almost forgott about those.
Guess it's a 505 in that beauty? (I'm not at all biased ;) )
calibre 340
calibre 501
calibre 506
calibre 507
calibre 508
calibre L 636.5
calibre 1753
calibre 6651
Ranfft says its a record which longine acquisitioned, yours should be  recod  or longine 508 .mine is to change date by repeated pushing it dosn,t , you guys have a pic of the date jumper?
When I get the 5 star I'll open her up and we can look at it
And my guess on the Russian watch, the Sturmanskie is.. A poljot 3133 chronograph?
Yes it's a 3133 chronograph. I'm more intrested in the dial. What version and dating that one.
That one should be mid 90:s .. my memory might fail me,, but we have a bunch of Russian watch enthusiasts here which will correct me..
2 hours ago, manodeoro said:
May I guess the Reliance could have Lorsa ?
Possibly a P72 or P72A ?
Envoyé de mon Moto G (5) Plus en utilisant Tapatalk
Lorsa is of course a possibility..but since I didn't see the word FRANCE at the bottom of the dial.I thought JAPAN.
Edited by yankeedog
Spelling
That Reliance really looks like my Leon Piraguet 17 jewels ... case/bezel/crown/hands/etc ... even the design of the dial is similar except mine has a Lorsa P75 inside.
That's why I thought about a Lorsa P72
That a way.
Entirely possible! I have a Leon piradet with a slava movement..so who knows!
Good looking collection, Will you show that gorgeous creature " Buran". I have got a buren, never heard of buran.
Here ya go please excuse the pictures.
It's a Russian chronograph with a 3133 variant in it.40e0bde22b698469df993bf3d4b96505.jpg&key=bcb38b7836179d7c8babdcc5f943b11a94ad9b0b1727bbb52aed96f1cf5855d19d3a4372754048126b88ba5c5c96522b.jpg&key=b93c2ca69a510663375f4ea5a50d6a0bd27e9ef369c067b80609ea26e138897ff4bf25135df18d26e68e65ed0cd39871.jpg&key=cdc97d820ceac27339559126b845ea820d4a17ad033bc7100b27234d63b90c870adde61756b79b0d738824ee6c1ac41c.jpg&key=6c6c543bae7146fa71cde66dadd0cc35e934e169e14663c91ac6a8ebed24d6c6e5d1cd6318310843447f4c1490d3acd1.jpg&key=335fa287022c6c8e9f2ac4aa49cc5ceec4f72ea2115e9af0a46bffcb6df1c32f
    • Update: The demagnetization only helped temporarily, maybe it pulled the wheels into a position where they liked each other. I have to adjust the sub second hand as it is a bit angled upwards and catching the minute hand stopping the whole movement but before this happened there were some wild deviations. HWGIKE#58 Alarm clock, cooked in hot cleaning fluid and oiled gently. This is a movement so I count it. 🙂 A while ago it tried to fly away one day, it was on my windows sill, we had strong wind the curtain flew like a flag and doing so encouraged my clock to do the same...  went out and ended up on the roof above the entrance door, its door in pieces but the clock itself suffered no damage otherwise. The original glass was already broken when I received it I still have the bottom part in two pieces. The new "glass" is acrylic. It also had a paper in the back in the case inside but it disintegrated, I still have a little bit of  piece of that too.     HWGIKE#59 Durowe 870 / Times M84 This particular instance is a D870, when I saw its worn out contact pin I thought that it must be a design flaw, and here we go: https://17jewels.info/movements/d/durowe/durowe-870/ An incredible movement again where the balance wheel drives the train and has two magnets one for the balance wheel/coil and one for the pallet. The magnet for the pallet is basically the "draw" one direction. The coil is about 1.8kOhm and one end is in contact with the main plate and the other end is soldered to a contact pin which is insulated by the means of putting it into a jewel and this contact pin is rubbing against a wire getting the energy/impulse as it is passing. Behind the contact pin there is an "impulse jewel" not sure why is it there... the wire seems to hit the impulse jewel first then the contact pin but maybe it is there only for insulation purposes? I was almost certain that the screw holding down the battery - (minus) clamp had no insulation washer.. i only noticed the green stuff around it coming from battery leakage... anyway the + and - had a shortcut which took me a while to realize.. had to fabricate one insulating washer on my own. The jewel settings were dirty but not it is all cleaned and oiled. The contact pin might work for a while but I am sure it has a short life. It is a front loader the whole thing is held together by the case so it is not possible to regulate it without putting it all together and taking the movement out of the case again, very inconvenient. A wonderful movement but not made for eternity only for the consumer market.
