I think a chronograph grade movement powers this, like the iconic ploprof. So unless its service time, it should keep excellent accuracy.
Regards
Regards
Co-axial chronometer grade.
Edited by noirrac1j
chronometer grade.
Regards
Was just serviced in 2017. Papers from Omega stated it had a crystal swap, bracelet and case refinishing and overhaul. So it should be good to go for a few more years. Does anyone know how many years between servicing does Omega reccomend?
Sent from my SM-G965U using Tapatalk
11 minutes ago, jameswarner1011 said:
depends on use, but start thinking of servicing after 4  to 5 years.
J
Ah, co-axial, I love them, though I don,t have one. Is this the one that fork delivers impulse both in clock& anticlock? Omega bought the design ( british designer)  for less than $25 developed and solely owns and makes the pieces. How would you like to adjust pallets on them.
   filling the case with the proper gas and good oiling should double the life of the watch.  number of years between servacing - debatable.  vin
    • By the way, I opened my watch, looked under a magnifying glass, there is simply no grease, the screws are without traces, the slots are intact.I think it's just a matter of maintenance.there are no rotor marks on the body. And to remove the strap from yours, just press on the 1st side,and slightly move the strap, then on the other side and it will come off.
    • Hi My name is Chris. Just started trying to learn about watch and clock repair as a result of repairing my fathers old 1890s police station clock (about a year ago). The clock was Ok, but having graduated to pocket watches and then wrist watches, despite the really excellent stuff on Youtube, I am struggling a bit.  As a retired engineer, I find the engineering exquisite, but a bit on the fiddly side.  I have done a few practice watches with a little success but failed a few, but have had success with Seiko 7005s, 7009s etc, but have just attempted a citizen 5430.  Nightmare.  My wife thought I had found religion as I spent so much time on my knees with my eyes to the floor looking for springs.  Got through that and found that the balance is shot.  Trying to source one or something that will fit from the citizen range has me totally perplexed.  Tried Ebay, Cousins etc without luck.  Any advice as to alternatives that will fit or alternative sources would be gratefully received.
    • I have only been a member for six years & I have found this a very friendly forum although I don’t have anything to do with watches not because I don’t like watches but because I have gout in both hands so my dexterity isn’t very good, I restore torsion clocks & occasionally other antique clocks also at 72 my eyes are not what they used to be, that is why I only post on the clock forum & the lathe forum mostly . As others have said Mark it is much appreciated that  you are willing & able to do this. very many Thanks Dell
    • Ah, this is brilliant, thank you very much!
