It's a roller remover. That one has a couple of extra inserts, usually it's 3. I think it's a goofy tool for removing rollers but the inserts are probably handy for pulling hands or other odd friction fit pieces. I don't think Bergeon has sold them for 30 years or so.
I was looking at this last night roo.
I thought they were lantern chucks for screws, but couldn't figure out its purpose.
The 2 screws on the side of the base and the 2 on the top of the base what is their function?
The top two do not pass through the bottom of the base, as I thought they might of until I saw the other photos.
The extra thingies (spindles/runners/chucks whatever) go in the base and are held by the screws. The above tool has two more than normal which throws the logic off.
    • No mate. Sorry if that offends you! Also please don’t take threads off-topic. I thank you sir.
    • Thanks Mark I have uBlock Origin Lite add-on for my Windows Chrome browser, so I've never seen a single ad on this site ! It also removes all adds from Youtube - I couldn't bear to watch it without uBlock
