Books about cuckoo clock movements
GregC
Have a look at dperry428 on you tube. He repairs clocks especially cuckoo clocks. He has his own way which is not the way you would start out but he is knowledgeable and informative.
Cuckoo clocks are a little complicated in their workings so start out with a time only movement something like a mantle clock of an old wall clock. It’s fascinating pulling them apart, cleaning them up and getting them working again.
with your wood skills it’ll not be long before you’re making clock cases to rehouse them
As Squiiffy said look around you tube lots of videos about clock repiar.
I feel that at the moment you should look at ebay and buy a cheap working cuckoo, take off the carving and build your fret work around the body, that way you get a feel for what is required. Have a look how the movement works, what parts you need and cost them, plus labour. Then seach the web to see what other shops are selling for and that will give you an idea, although yours will be fret work and the others will be carved which gives you an edge.
Then after all that you can make the step into repairing movements as you need a few tools for that and it will take time to get good at it.
Don't buy battery operated cuckoo movements as there is no way you can compeat with the rubbish from China.
Here is a china battery made cuckoo.
https://www.ebay.com.au/itm/Europea-Cuckoo-Clock-House-Wall-Antique-Clock-Modern-Art-Vintage-Wood-Home-Decor/183696394018?hash=item2ac5288722:g:3TUAAOSwVRBcGLax
Here is a German made brass movement cuckoo.
https://www.ebay.com.au/itm/German-Cuckoo-Clock-Black-Forest-8-Day-Mechanical-1885-Replication-8TMT540-9/162021568278?hash=item25b93cef16:g:jAQAAOSwT5tWMLTT
Here is where I work, therefore I know a bit about cuckoo clocks.
https://clocks.com.au/
Hope this helps.
Sorry I should have read your post in the 'making a leather clock' before I wrote the above, just do this part if it is all a bit to stressful.
" I feel that at the moment you should look at ebay and buy a cheap working cuckoo, take off the carving and build your fret work around the body, that way you get a feel for what is required. Then after all that you can make the step into repairing movements as you need a few tools for that and it will take time to get good at it, however there are plenty of people on here to help.
Thanks for the replies guys, appreciated. I need to learn from the ground up as I only know how to cut wood and what I learnt from Mark's courses. I was watching a vid on youtube recommended by Squiffything and I guess cuckoo clocks look kind of hard for me at this stage so I guess ordinary clocks for now. Also, what specialty tools would I need? I have most of the basic tools handymen have like pliers, adjustable wrench etc. Thanks for any and all replies
This is a question that seems to come up a lot.
OH, as a Mod, maybe you could make a PDF or Word.doc with a basic list of what is required when starting out and store it somewhere on the site that can be downloaded by people new to clock repair?
Personal I've found books by Donald De Carle to be good reference material.
For clocks I have a copy of Practical Clock Repairing which I've found useful. Some may may not agree as it is a little dated but it covers a lot, including tools required, and is readily available both new and second hand for not too many beer vouchers.
Hope you find this useful.
NAD
Sent from my moto g(6) play using Tapatalk
    • HWGIKE#57 Valex FEF 190 15 jewels Swiss lever full service and repair This one was waiting for a balance staff replacement in my cabinet parts and case cleaned up with a new balance staff and a 4th wheel as the original 4th wheel had a broken pivot for the off center second hand. I never attempted a balance staff replacement before however I received a Bergeon Molfres (i was hunting it for about 2 years) and with the help of it I managed to remove the old staff and riveted the new one in. It also received a new MS, crystal and the hole for the MS arbor was also tightened. With the new MS now it has an acceptable performance meaning that the amplitude goes up to 280 fully wound, has an acceptable beat error and I have the two nice lines but only dial up, dial down is not as nice and I could not figure out as why. I have the two lines but the amplitude is dropping to around 230 and the lines are a bit hairy. Both dial up and dial down the lines just go up and down without seemingly any pattern. I cleaned the movement two times, and then a 3rd time pegged out the main plate and train bridge holes but made no change. Both the HS collet and the roller table was too lose on the new staff... I did not count how many times I took the balance cock off to sort out the HS collet, the roller table and the beat error, somebody before me also shortened the HS by pushing it out a bit and it seems every time somebody is messing with the end of the HS the protruding bit is most of the time twisted bent etc. This one was probably one of the most challenging repair and service. I might take the new MS out and clean it lubricate it as I just pushed the new one in to the barrel from the retaining ring. Plus started to re-read the theory of the escapement and how to analyse the graph on the timing machine: Greiner Chronografic Record manual. I am also thinking to put the watch on a 24 hour long run with the eTimer SW it once helped me to figure out what was wrong with a watch. There is an interesting part of the Greiner record manual talking about the pallets and the end shake of the balance and pallet staff. Maybe this is my issue? Who could that possibly identify? After a few years now I am still without a clue how could watchmakers make parts I can only see with my microscope or how could/can they carry out complicated services impossible to do.. real magic..... .... ..... before I sent this post while the pics were uploading I had an idea, i was browsing the possible outcomes on the timing machine I had one for magnetism..... so I demagnetized the movement and it is not hairy now.... two really nice lines 0.2 ms beat error still a bit wavy, but a lot lot better..... argh....
