Most Useless Watch Tool
jdrichard
I have a crystal lift like that, made by Vigor. It works, but seems a bit sketchy at how it grabs the edges of soft plastic with sharp metal. I'm sure that it puts scratches around the crystal even if you can't see them without magnification. Plus, it's always a pucker-factor 15 to get the crystal's diameter decreased enough to get it inserted. But since I don't have the proper Longines wrenches for monocoque cases, it's all I can use.
Just need a proper plastic crystal press.
You mean a GS type press? I do have one, but for some reason I didn't think it would work on my monocoque Wittnauers, etc. My thinking is that the GS press that I have, you have to put the crystal facing down in the support. The case, generally without a back, has to go over the plunger facing downward in order drop over the crystal. With the one-piece case, the back is not removable, so the plunger cannot pass through a bezel or open back case. Am I wrong, or is this a different type than you are referring to?
I use mine regularly, as vinn3 states on vintage watches.
Just used it the other day to fit a 14.4mm crystal onto a late 1950s ladies Certina.
That's the smallest crystal I've fitted and it was nearly at the limit of my tool as I just have the cheap Anchor brand one, but it has worked every time I have used it..
You also need the small base for holding the crystal for the tool to work though, this makes the claw grip the crystal just off the base of it so you can drop the crystal home whilst still compressed and then release the tension and it just expands into place.
I've just used both the lift tool, and the crystal press, in the process of fixing a Timex. They are a little tricky to get right, and they don't work well in every case, and I did manage to drop the movement on the floor due to my ham-fisted efforts with the lift tool.
I wouldn't say it is  *THE* most useless tool, but perhaps one of the most tricky to use, and not appropriate for some crystals.
Popping the crystal out is often much easier with your thumbs, but obviously you can't do that with a front loader.
I was going to nominate one of these...
hammer.jpg&f=1
... but I believe there are a few people who use them to 're-allign' Timex watches.
Sacrilege to my eyes.
Using it to 're-alligning' an overpriced  Daniel Wellington, or maybe a dime store quartz possibly I could forgive, but not a Timex.  :P
just used my crystal lift on a friends roamer(question posted earlier!) and it was a doddle both off and on.mine is a Liberty made in india,a good price and quite solid.does the job well.also use a crystal press when needed.both handy to have.B
I find removing the crystal May be ok, however, installing it with those very touchy claws is way too difficult.
hammer.jpg%26f=1&key=b24d126953cea2e57cb43cdd67a9e6af46678fe4b0c8ddde7ceb61f3949788fa
Using it to 're-alligning' an overpriced  Daniel Wellington, or maybe a dime store quartz possibly I could forgive, but not a Timex.  [emoji14]
Is that a Left or Right Handed Hammer?
I too use my thumbs to pop out the crystal and a front loader would need the claws??
3 minutes ago, jdrichard said:
... and a front loader would need the claws??
I grabbed the crystal with the claws, then held the lift tool between my knees and gave the movement plate a playful tap with a plastic rod and the useless tool I mentioned above.
Not the most subtle method, but very reliable for sending the watch in to orbit, and you do need to do that at least once a week, or you 'aint trying hard enough. Second try worked like a charm, and the movement, crystal and movement plate parted with the case quite nicely.
Something makes me suspect there may be a better way of doing this.
I nominate the 3D printed mainspring winder that I printed and tried yesterday which successfully butchered a Seiko 7019A mainspring for me. :thumbsu:
At least that spring wasn't in the best fettle to begin with.
Back to winding in by hand unless someone wants to donate a spring winder set?:D
Back to winding in by hand unless someone wants to donate a spring winder set?[emoji3]
Spring winder sets are easy to find on eBay. Or just do it by hand.
But you printed a mainspring winder?! Do you have a photo.
I wonder if I could scale that up to work with my aircraft clocks as the NOS alloy mainsprings I've got I can't wind in by hand and they are too big for all my watch spring winders and too small for my clock spring winders.
    • HWGIKE#57 Valex FEF 190 15 jewels Swiss lever full service and repair This one was waiting for a balance staff replacement in my cabinet parts and case cleaned up with a new balance staff and a 4th wheel as the original 4th wheel had a broken pivot for the off center second hand. I never attempted a balance staff replacement before however I received a Bergeon Molfres (i was hunting it for about 2 years) and with the help of it I managed to remove the old staff and riveted the new one in. It also received a new MS, crystal and the hole for the MS arbor was also tightened. With the new MS now it has an acceptable performance meaning that the amplitude goes up to 280 fully wound, has an acceptable beat error and I have the two nice lines but only dial up, dial down is not as nice and I could not figure out as why. I have the two lines but the amplitude is dropping to around 230 and the lines are a bit hairy. Both dial up and dial down the lines just go up and down without seemingly any pattern. I cleaned the movement two times, and then a 3rd time pegged out the main plate and train bridge holes but made no change. Both the HS collet and the roller table was too lose on the new staff... I did not count how many times I took the balance cock off to sort out the HS collet, the roller table and the beat error, somebody before me also shortened the HS by pushing it out a bit and it seems every time somebody is messing with the end of the HS the protruding bit is most of the time twisted bent etc. This one was probably one of the most challenging repair and service. I might take the new MS out and clean it lubricate it as I just pushed the new one in to the barrel from the retaining ring. Plus started to re-read the theory of the escapement and how to analyse the graph on the timing machine: Greiner Chronografic Record manual. I am also thinking to put the watch on a 24 hour long run with the eTimer SW it once helped me to figure out what was wrong with a watch. There is an interesting part of the Greiner record manual talking about the pallets and the end shake of the balance and pallet staff. Maybe this is my issue? Who could that possibly identify? After a few years now I am still without a clue how could watchmakers make parts I can only see with my microscope or how could/can they carry out complicated services impossible to do.. real magic..... .... ..... before I sent this post while the pics were uploading I had an idea, i was browsing the possible outcomes on the timing machine I had one for magnetism..... so I demagnetized the movement and it is not hairy now.... two really nice lines 0.2 ms beat error still a bit wavy, but a lot lot better..... argh....
