Hi there!
I’m trying to remove a canon pinion with the appropriate just bought tool but the pinion doesn’t come off. Problem is that it is sliding, there is no shape to hang on.
Any idea ?
Guess that is an pocket watch with a press fit canon pinion?
You probably need a staking set and gently tap it out.
(P.S . Nexttime just post in the Watch Repairs Help & Advice, makes everything easier)
Edited by HSL
Hi HSL and thanks for your answer.
Yes it's a pocket watch. A staking set seems something I can’t afford for the moment. Any other solution?
Well the thing with this tool is so you can align it straigt but I guess everything you could use to get the same effect goes.
The cannon pinion is slightly conical so you only have to get the second wheel to go downwards in a gentele way.
Will attache a picture so you get the idea.. (Here I am pressing it back).
To be sure to understand, you press on the canon pinion with your tool to be sure it’s straight against the watch plate and then you pull the second wheel down? If so, how do you pull it without moving?
Not on the canon pinion just the little top of the second wheel, it will just slide straight down
Later you have to press it on again.
    • By the way, I opened my watch, looked under a magnifying glass, there is simply no grease, the screws are without traces, the slots are intact.I think it's just a matter of maintenance.there are no rotor marks on the body. And to remove the strap from yours, just press on the 1st side,and slightly move the strap, then on the other side and it will come off.
    • Hi My name is Chris. Just started trying to learn about watch and clock repair as a result of repairing my fathers old 1890s police station clock (about a year ago). The clock was Ok, but having graduated to pocket watches and then wrist watches, despite the really excellent stuff on Youtube, I am struggling a bit.  As a retired engineer, I find the engineering exquisite, but a bit on the fiddly side.  I have done a few practice watches with a little success but failed a few, but have had success with Seiko 7005s, 7009s etc, but have just attempted a citizen 5430.  Nightmare.  My wife thought I had found religion as I spent so much time on my knees with my eyes to the floor looking for springs.  Got through that and found that the balance is shot.  Trying to source one or something that will fit from the citizen range has me totally perplexed.  Tried Ebay, Cousins etc without luck.  Any advice as to alternatives that will fit or alternative sources would be gratefully received.
    • I have only been a member for six years & I have found this a very friendly forum although I don’t have anything to do with watches not because I don’t like watches but because I have gout in both hands so my dexterity isn’t very good, I restore torsion clocks & occasionally other antique clocks also at 72 my eyes are not what they used to be, that is why I only post on the clock forum & the lathe forum mostly . As others have said Mark it is much appreciated that  you are willing & able to do this. very many Thanks Dell
    • Ah, this is brilliant, thank you very much!
