Scrollsaw Cuckoo Clock
GregC
6 hours ago, JimmyD said:
It depends on the type of movement you are putting in the clock, battery or brass?
The first will be battery as 10 yrs ago when I was all gung ho for scrolling I bought everything for 3 clocks. Now that I'm closer to completion I'm thinking I could make the cavity deeper to fit a real cuckoo mvmt. I just need to know if they are a standard height
Regula make a 1 day and 8 day movement, these can be bought at time savers. A few things you need to know, the depth, the movement will need to be screwed to the inside of the face board, so about 6 mm think blocks need to be glued on to take the screws, then add the distance from the mounting bracket to the tip of the crutch, then add another 50mm so you have enough room for the cuckoo belows. The hight is dictated by where  the hands arbour hole is placed on the face. The width you have already since you have made the frets. Have a look on eBay at cuckoo clocks for sale to see how they are normally set up on the inside to give you an idea.
First one is going to be quartz. I just measured the darn thing and forgot the dimensions. I think its 4" wide by 6" high. Original plan has it 2" deep but I can alter it to make it deeper.
36 minutes ago, JimmyD said:
I think the 1st photo looks better with more of a contras, just remember to put the dial with the 12 at the top.
I thought so too but I just realized how the color is like that. I didnt read the directions for the stain and didnt wipe the excess off thats why its so dark. I hope these old messed up brains can remember to put XII at the top, lol  ;-)
Now that this project has been completed, I hope that some of you might be inspired to pick up a scroll saw and try out this craft. Its not hard, just tedious and repetitive but you can make some beautiful pieces of art and there are all kinds of patterns out there for everything one could imagine. This clock is not difficult at all, there are clocks that take guys months or even years to make. Cherry tree toys has the most awesome patterns I've come across and Berry basket has some simple yet beautiful stuff, in fact this clock is from a pattern by Cherry tree toys.
https://cherrytreetoys.com/scroll-saw-patterns/
https://www.berrybasket.com/
    • HWGIKE#57 Valex FEF 190 15 jewels Swiss lever full service and repair This one was waiting for a balance staff replacement in my cabinet parts and case cleaned up with a new balance staff and a 4th wheel as the original 4th wheel had a broken pivot for the off center second hand. I never attempted a balance staff replacement before however I received a Bergeon Molfres (i was hunting it for about 2 years) and with the help of it I managed to remove the old staff and riveted the new one in. It also received a new MS, crystal and the hole for the MS arbor was also tightened. With the new MS now it has an acceptable performance meaning that the amplitude goes up to 280 fully wound, has an acceptable beat error and I have the two nice lines but only dial up, dial down is not as nice and I could not figure out as why. I have the two lines but the amplitude is dropping to around 230 and the lines are a bit hairy. Both dial up and dial down the lines just go up and down without seemingly any pattern. I cleaned the movement two times, and then a 3rd time pegged out the main plate and train bridge holes but made no change. Both the HS collet and the roller table was too lose on the new staff... I did not count how many times I took the balance cock off to sort out the HS collet, the roller table and the beat error, somebody before me also shortened the HS by pushing it out a bit and it seems every time somebody is messing with the end of the HS the protruding bit is most of the time twisted bent etc. This one was probably one of the most challenging repair and service. I might take the new MS out and clean it lubricate it as I just pushed the new one in to the barrel from the retaining ring. Plus started to re-read the theory of the escapement and how to analyse the graph on the timing machine: Greiner Chronografic Record manual. I am also thinking to put the watch on a 24 hour long run with the eTimer SW it once helped me to figure out what was wrong with a watch. There is an interesting part of the Greiner record manual talking about the pallets and the end shake of the balance and pallet staff. Maybe this is my issue? Who could that possibly identify? After a few years now I am still without a clue how could watchmakers make parts I can only see with my microscope or how could/can they carry out complicated services impossible to do.. real magic..... .... ..... before I sent this post while the pics were uploading I had an idea, i was browsing the possible outcomes on the timing machine I had one for magnetism..... so I demagnetized the movement and it is not hairy now.... two really nice lines 0.2 ms beat error still a bit wavy, but a lot lot better..... argh....
    • Wie ging die Sache weiter?   please use English for your posts    Tom
