Hello all,
    Please indulge me.We have all opened up "quartz fashion watches"  to see a fairly large case with a very small movement and a huge plastic spacer. These movements are very close in size and shape to  ladies jeweled mechanical movements..has anyone done this swap ? If not does anyone reckon that one of these movements would have the torque to turn hands large enough to fit on say a 30 mm dial?I know that in most cases you would loose the second hand. But it would be a way to repurpose movements that have fallen into disuse and a way to perhaps create something unique.
It is on my list of things to try. I to have quite a collection homeless of small quartz movements.
The issues would be getting hands that fit, and positioning the crown at the correct height, always assuming of course that you are going to glue the movement to the dial, since the dial pegs on a quartz movement are very unlikely to line up with the dial feet on the old dial.
It all seems relatively straightforward, but I haven't tried it yet.
I don't think it would be a problem, at least not one that I've encountered. Most of these cheap Chinese pocket watches have tiny movements.
I tend to use Miyota since they are only a couple of pounds and I can be sure of finding hands to fit.
I'm not sure about Andy's idea of gluing the dial. OK you can adjust the thickness of glue to bring your crown in line, but in my experience the problem is gauging the void between the hour wheel and dial. Too big a gap and the hour wheel disengages if you tip it upside down.
This is a novelty pocket watch bought for my birthday.
I hope you didn't think we were talking about this kind of movements.
... before you ask.. no I didn't buy this watch... tempted perhaps... but no. I do have standards.. low ones arguably, but standards none the less.
Edited by AndyHull
Thats one my son would find hilarious, BRB, got to ebay. :D
    • Hello and welcome from Leeds, England . No idea about Citizen but someone will advise soon.
    • Hi Chris and welcome to the forum, The hands and knees is by way of the rite of passage, we have all done that at some time or another.   Added a bit of citizen gen plus the T Z glossary Citizen Technical Information.pdf TZIllustratedGlossary.pdf
    • By the way, I opened my watch, looked under a magnifying glass, there is simply no grease, the screws are without traces, the slots are intact.I think it's just a matter of maintenance.there are no rotor marks on the body. And to remove the strap from yours, just press on the 1st side,and slightly move the strap, then on the other side and it will come off.
    • Hi My name is Chris. Just started trying to learn about watch and clock repair as a result of repairing my fathers old 1890s police station clock (about a year ago). The clock was Ok, but having graduated to pocket watches and then wrist watches, despite the really excellent stuff on Youtube, I am struggling a bit.  As a retired engineer, I find the engineering exquisite, but a bit on the fiddly side.  I have done a few practice watches with a little success but failed a few, but have had success with Seiko 7005s, 7009s etc, but have just attempted a citizen 5430.  Nightmare.  My wife thought I had found religion as I spent so much time on my knees with my eyes to the floor looking for springs.  Got through that and found that the balance is shot.  Trying to source one or something that will fit from the citizen range has me totally perplexed.  Tried Ebay, Cousins etc without luck.  Any advice as to alternatives that will fit or alternative sources would be gratefully received.
