UTS Quartz movement
Davey57
Sorry, look away now OldHippy. I know you dislike them:lol:
A friend has asked if I can do anything with his wife’s kitchen clock that she loves dearly as it belonged to someone close. He says it was losing time although, it has been running perfectly with me for almost two weeks. Rather than give it back to find the problem returns I have been looking for a new movement. I have found one that is exactly the same here https://www.ebay.co.uk/itm/New-Replacement-UTS-01248-Quartz-German-Euroshaft-Movement-Mechanism-13mm-Shaft-/183725493748?_trksid=p2385738.m4383.l4275.c10&var=691309729771
Cousins have a one that I reckon should do, I just wanted to check. https://www.cousinsuk.com/product/hi-torque-uts
The only difference I notice is the distance from the front of movement to centre of shaft tip. Mine is 13mm same as the more expensive one, Cousins is 11mm.  Which should I go for please.
You could get one of each size from Cousins and by trial and error fit the one best suited. Also a suitable set of hands ordered at the same time would leave a spare complete movement and a repaired clock for less than the ebay item.
If the shaft is too long. You can always pack it with these sorts of washers. The large black type in this photo. Its always better to be a bit long than short. Just make sure you have good clearance of the face and the glass.
Not sure if this will inspire you further, but here are a couple of clocks I made from scrap.
The cloth balloon I made while I was fixing up our sewing machine, and the simple dinner plate one was as much an experiment in drilling holes in ceramic as anything else.
RIMG0263.thumb.JPG.4cb06d8bf76fc54634022b494dd13add.JPGRIMG0263.thumb.JPG.4cb06d8bf76fc54634022b494dd13add.JPG
The Chinese movements they use are cheap as chips on ebay.
There are a couple of others around the house, but these are probably the most off the wall designs I've done so far.
Cheers, I’ll have a look.  I’ve already bought a couple from Cousins plus a few sets of hands. When I have time I’m looking forward to making them into something. One thing though, the hands are a loose fit on the shaft of the movement. Is it normal to have to pinch them a little so that they hold?
I have a 20 year old clock with the same movement. I think it has a similar problem to the original poster. It keeps time, but occasionally falls well behind (in a dramatic way -- I think that it may stop for some minutes and then restart). Seems to happen more with semi-depleted battery, but not always.
I too only see the same replacement part listed on ebay -- assume this must be discontinued.
Have you found a correct alternative?  If so, can you let us know which model number movement is known to work?
  • 1 year later...
Hello Chippy and welcome to the forum.  There are m any suppliers of quartz clock movements, Cousins UK      H.S.Walsh both  material houses    or newgeneration clocks. on the links below.
https://ngclocks.co.uk/      https://www.cousinsuk.com/department/watch-parts       https://www.hswalsh.com/categories/watch-parts-straps-batteries
    • HWGIKE#57 Valex FEF 190 15 jewels Swiss lever full service and repair This one was waiting for a balance staff replacement in my cabinet parts and case cleaned up with a new balance staff and a 4th wheel as the original 4th wheel had a broken pivot for the off center second hand. I never attempted a balance staff replacement before however I received a Bergeon Molfres (i was hunting it for about 2 years) and with the help of it I managed to remove the old staff and riveted the new one in. It also received a new MS, crystal and the hole for the MS arbor was also tightened. With the new MS now it has an acceptable performance meaning that the amplitude goes up to 280 fully wound, has an acceptable beat error and I have the two nice lines but only dial up, dial down is not as nice and I could not figure out as why. I have the two lines but the amplitude is dropping to around 230 and the lines are a bit hairy. Both dial up and dial down the lines just go up and down without seemingly any pattern. I cleaned the movement two times, and then a 3rd time pegged out the main plate and train bridge holes but made no change. Both the HS collet and the roller table was too lose on the new staff... I did not count how many times I took the balance cock off to sort out the HS collet, the roller table and the beat error, somebody before me also shortened the HS by pushing it out a bit and it seems every time somebody is messing with the end of the HS the protruding bit is most of the time twisted bent etc. This one was probably one of the most challenging repair and service. I might take the new MS out and clean it lubricate it as I just pushed the new one in to the barrel from the retaining ring. Plus started to re-read the theory of the escapement and how to analyse the graph on the timing machine: Greiner Chronografic Record manual. I am also thinking to put the watch on a 24 hour long run with the eTimer SW it once helped me to figure out what was wrong with a watch. There is an interesting part of the Greiner record manual talking about the pallets and the end shake of the balance and pallet staff. Maybe this is my issue? Who could that possibly identify? After a few years now I am still without a clue how could watchmakers make parts I can only see with my microscope or how could/can they carry out complicated services impossible to do.. real magic..... .... ..... before I sent this post while the pics were uploading I had an idea, i was browsing the possible outcomes on the timing machine I had one for magnetism..... so I demagnetized the movement and it is not hairy now.... two really nice lines 0.2 ms beat error still a bit wavy, but a lot lot better..... argh....
