 Over the last couple of weeks, I have been re-jigging my workshop so I can do Watch repairs in a more orderly manner.
Its a work in progress but coming on pretty nicely.
Best wishes from Jon.
What lighting do you have? Is that your ultrasonic little cleaner over in the right hand corner, or do you have a proper watch cleaner.  It takes a long time to plan a workshop. It will never be big enough.:D
I am currently using strip lighting and an LED bench / desk light, and yes that is my ultrasonic on the right which I will be changing for a bigger one.:)
    • No mate. Sorry if that offends you! Also please don’t take threads off-topic. I thank you sir.
    • Thanks Mark I have uBlock Origin Lite add-on for my Windows Chrome browser, so I've never seen a single ad on this site ! It also removes all adds from Youtube - I couldn't bear to watch it without uBlock
