no other reason to work on this one other than to say "I fixed it".
First up will the before  and I will follow latter with the after.
and here is the after - NOS case, crown\stem and movement.  Crystal buffed out, dial has signs of the damage that occurred but she is running again.  Now this is not a sort after vintage Timex but since I had the parts a figured what the heck.  The kicker even though I did give the movement a quick test before installing it did fail latter on.  I tried several times to clear it out with cleaner spay and followed with lube. But it just would not go.  Than yesterday I popped the battery back in and off she went running right on time.  Could have been some of the cleaner did not flush out and was shorting somewhere.    Well she is running now!
pretty nice. but please do something about the band!those spring loaded stainless steel ends will auger their way into that pot metal case.
Timex Thursday again for me.
A 1967 Timex Viscount "Selfwind"  - If you look  in the background, you can see I was checking on the seedlings on the window ledge, which are coming along nicely.
3 hours ago, AndyHull said:
@JerseyMo Have you had much success with repairing or replacing the contacts in the early Timex electricals? These seem to be the weak pint in that design.
Which are you referring to, the electro-mechanical or the early quartz?
the negative lead is connected to contact wire.  so if the lead is gone or damage, you will have to replace the part. Of course if it is damaged the coil on the balance may also be shorted.  So the repairs gets more involved.  You have to be careful with those movements because even though the parts look very much alike and even fit they are quite different.  For example an "Electronic" balance assembly has an integrated diode.
