The black wheel is not the same as 7S26. I tried swapping them so I had to fix the teeth on the original gear.  The movement is now advancing the day/date. My question now is, did I screw this up by changing the day wheel or was this a factory defect? I'm tending towards factory defect and I guess it was my fault that I didnt try advancing it before I replaced the wheel. What would you guys do who have more experience with watches?
Update: A few more turns and its back to square 1....the wheel is back to not turning so its **BLEEP**ed and the c clip pulled a disappearing act on me.
Altough there are two version of the black day/date driving wheel, you can't mix these up because one has a male pivot, and the other is female. Otherwise  I can't understand what are you talking about. When in doubt you can check my parts reference sheet:https://docs.google.com/spreadsheets/d/e/2PACX-1vRN2UULQKTfKmhRStZhDdIOIQrqd6sPB-g6x2SKyQQjOvTBjG_7TQXQhAT4f1WqAX5QAPkIimi-3jqd/pubhtml
The c-clip has pinged away because it wasn't fully seated, probably due to the day disc not being installed correctly. Just like other systems the calendar work is delicate, you need to be sure that everything is square and seated before moving on.
What I was referring to is the black wheel. I tried to replace the one with the damaged teeth from the nh36 mvmt with one from the 7S26 and found that the pivot point underneath is different so I tried to straighten the teeth which worked for a few date changes but eventually it gave out. When I took off the c clip to check if the black wheel was turning that was when it pinged away but the ones from the 7s26 work.
    • By the way, I opened my watch, looked under a magnifying glass, there is simply no grease, the screws are without traces, the slots are intact.I think it's just a matter of maintenance.there are no rotor marks on the body. And to remove the strap from yours, just press on the 1st side,and slightly move the strap, then on the other side and it will come off.
    • Hi My name is Chris. Just started trying to learn about watch and clock repair as a result of repairing my fathers old 1890s police station clock (about a year ago). The clock was Ok, but having graduated to pocket watches and then wrist watches, despite the really excellent stuff on Youtube, I am struggling a bit.  As a retired engineer, I find the engineering exquisite, but a bit on the fiddly side.  I have done a few practice watches with a little success but failed a few, but have had success with Seiko 7005s, 7009s etc, but have just attempted a citizen 5430.  Nightmare.  My wife thought I had found religion as I spent so much time on my knees with my eyes to the floor looking for springs.  Got through that and found that the balance is shot.  Trying to source one or something that will fit from the citizen range has me totally perplexed.  Tried Ebay, Cousins etc without luck.  Any advice as to alternatives that will fit or alternative sources would be gratefully received.
    • I have only been a member for six years & I have found this a very friendly forum although I don’t have anything to do with watches not because I don’t like watches but because I have gout in both hands so my dexterity isn’t very good, I restore torsion clocks & occasionally other antique clocks also at 72 my eyes are not what they used to be, that is why I only post on the clock forum & the lathe forum mostly . As others have said Mark it is much appreciated that  you are willing & able to do this. very many Thanks Dell
    • Ah, this is brilliant, thank you very much!
