Hi All
I am working on a Tag CAP2110 Aquaracer and the bezel ratchet spring is missing. I need to get a new one. OD 38 approx. ID 35 approx. Can someone point me in the right direction please.
Thanks in advance.
Hi All
Thanks in advance.
Cas-ker maybe......eslinger is also a good place but you may get the "are you a watchmaker" interrogation. Ofcourse ebay is another last resort.
Sent from my SM-G950U using Tapatalk
Esslinger? I have ordered from them several times. No watch Gestapo there.
Its probably just me......lol. Im sure I sound like a complete novice when I call. I cant remember which one, although I know it wasnt CasKer. They actually wanted a copy of my "certification" when I called to order parts. It was one of the major distributors though I do know that.
I wouldn't be surprised if parts houses all dislike filling small, non-watchmaker orders. I remember that La Rose was very good about this, but they really expected you to know what you were ordering before you called. The reality is that when it comes to the novice and watch-parts, there's just no money in it after you factor in phone time, higher potential for returns, etc. You understand this, I'm sure. If you order online after figuring out the part information, you shouldn't have any problems getting an order in.
Good luck with the Tag. They may be part of the watch cartel, so a factory part may be difficult. But for a bezel spring that shouldn't really matter if it's an aftermarket. Cheers.
  • Similar Content
    • This conversation is becoming a very confusing. The etachron system is a very nice system for manufacturing watches. As you know it consists of two components the stud and the regulator pins. Beautiful thing of this system is you can open up your regulator pins center the hairspring and as you close the pins they will close equally on both sides providing you centered it in the first place. It's not like you're going to become closer to one side or the other as the definition of the regulator pins is a bit confusing it's not exactly a slot sort of. I'm thinking maybe a little eight reading will be helpful for you. Then the file name was changed by me at the US patent but the wording of Seiko may or may not actually be attached to it soared up? I just did that so I can find it in my files. Normally patents are in people's name if they work for a company the company name will be there you'll notice the person lives in Japan which is interesting as the name would imply that this is a Swiss product. Somewhere I think I have the patents for the stud and I believe that is Swiss like a lot of things their Japanese and Swiss and then the Japanese let the Swiss name stand as it seems you more popular in case as you read up on the patents of the regulator pins or pin will see and it should explain exactly how and why it works also why it's important to always close at an open in specific directions because the pins actually have a shaped to them it's very hard to see the shape as it's very tiny.   As a reminder with this system it's mass-produced. I wouldn't be at all surprised if they use cameras and computers to do all of the adjustments.  The meaning of this is that the majority of watches will function as there supposed to and do what they're supposed to do the system will allow us for some minor in tolerance and has more than likely as I said no human hand is ever touched those watches that's the way they left the factory and they work fine. US2007091729A1 seiko etachron.pdf
