Part of Workshop Practice Series, by Tubal Cain {he must have been good a at milling tubes I guess). ISBN 978-085242-840-5
By mistake I've bought two, Amazon refunds but doesn't want it back :blink:. Free to the first who wants it.
Edited by jdm
34 minutes ago, Mark said:
I wouldn't say no :)
Then I'll need your new address, as you'll get it in person. Have you rescued your lathe BTW?
No problem. Our new house is not far from the old. Let me know when you're coming next and I'll get Fon to cook you up some nice Green Curry.
But I will be travelling to the UK on the 22 July for 2 weeks. You have my Line.
Sent from my SM-G950F using Tapatalk
    • No mate. Sorry if that offends you! Also please don’t take threads off-topic. I thank you sir.
    • Thanks Mark I have uBlock Origin Lite add-on for my Windows Chrome browser, so I've never seen a single ad on this site ! It also removes all adds from Youtube - I couldn't bear to watch it without uBlock
