Hi, I would like some advice on how to remove the stem and crown from my vintage timex.
From my research it would appear that I have a model 29 movement but but I can't identify the bolt screw or lever. Can anyone help?
Back story: I started playing about with Seiko SKX watches and modding them as a hobby during my wind down year as a teacher. I have a number of vintage Timex watches and renovate them.
Regards
Tom
Regards
Tom
Hi Tom and welcome to this forum . Well , I show you where you have to unscrew a screw. Do not unscrew too much, just enough to take out your crown . very simple ;) However , i didnt find the model 29 . But if your movement is similar to this picture , this is the thing to do . Have a great day . , i
Edited by SeikoWatch
that is not a model 29 - rather it is a 24 or 25
    • By the way, I opened my watch, looked under a magnifying glass, there is simply no grease, the screws are without traces, the slots are intact.I think it's just a matter of maintenance.there are no rotor marks on the body. And to remove the strap from yours, just press on the 1st side,and slightly move the strap, then on the other side and it will come off.
    • Hi My name is Chris. Just started trying to learn about watch and clock repair as a result of repairing my fathers old 1890s police station clock (about a year ago). The clock was Ok, but having graduated to pocket watches and then wrist watches, despite the really excellent stuff on Youtube, I am struggling a bit.  As a retired engineer, I find the engineering exquisite, but a bit on the fiddly side.  I have done a few practice watches with a little success but failed a few, but have had success with Seiko 7005s, 7009s etc, but have just attempted a citizen 5430.  Nightmare.  My wife thought I had found religion as I spent so much time on my knees with my eyes to the floor looking for springs.  Got through that and found that the balance is shot.  Trying to source one or something that will fit from the citizen range has me totally perplexed.  Tried Ebay, Cousins etc without luck.  Any advice as to alternatives that will fit or alternative sources would be gratefully received.
    • I have only been a member for six years & I have found this a very friendly forum although I don’t have anything to do with watches not because I don’t like watches but because I have gout in both hands so my dexterity isn’t very good, I restore torsion clocks & occasionally other antique clocks also at 72 my eyes are not what they used to be, that is why I only post on the clock forum & the lathe forum mostly . As others have said Mark it is much appreciated that  you are willing & able to do this. very many Thanks Dell
    • Ah, this is brilliant, thank you very much!
