Just doing a bit of casual eBay browsing this morning and I came across this rather intriguing listing 191447636211.
Curious about what made it tick I had a look at the movement shot.
Is it me or does the dial appear to claim 17 jewels? If so, where the hell are they all?
And what about "shock protected"?
Apart from the obviously mismatched crown though, the thing that really has my mind proper boggled is the text on the watch back.
"Diamond Tooled" is one that crops up quite often on cheaper watches. "Tropicalized" is a nice touch but is a bit ambiguous as to exactly what it means.
However.....
That does say "Radar Tested" doesn't it?
What in the name of all that is horological does that actually mean?
Perhaps some kind of navigational safety feature aimed at aviators or those of a nautical persuasion that enables them to be located using radar in the event of a mishap?
Or of course it could be the exact opposite; some kind of stealth watch that avoids radar detection?
Can anyone else enlighten me?
If you have any similar examples of utterly baffling claims on watches I would love to see them posted on here.
I rekon it used to belong to Robert Watson Watt. Snap it up quick before Will sees it, it could be worth a fortune. :-)
Anil, I see what you mean.
That is a very subtle distinction but it makes all the difference.
 Marc.
Please guys, you haven't understood a bit:
The jewels are in the tiny "diamond tools" used to make the watch (17 tools total used in this process in a shop by a river, probably a main artery since the "r" is capitalized), if any has fallen inside by mistake, the radar stealth feature is concealing them properly. As a nice touch, you have to be mindful of the reminder on the dial to "shock protect" the watch i.e. not to subject it to shock! The fish, well it is a nice touch too, but the radar will not locate them when you are out there fishing! :)
Cheers,
Bob
    • I doubt it is due to lack of amplitude.  My 7750 - which I haven't serviced yet because the numbers were OK (and I am still scared of chronographs!)- has no problem flipping the date with an amplitude closer to 250º On other movements I have had issues where the plate(s) that go over the calendar wheel interfere.  I did an FHF ST 96-4 last week where there are 2 tiny plates plus a larger plate that hold the calendar wheel in place and I had real problems getting the calendar wheel to snap around nicely.  Lubrication on the points of the teeth of the calendar wheel and making sure the small plates were aligned properly was the solution there.
    • Well I spoke too soon. Here's where I am now with this issue. I replaced the date jumper and all seemed to function correctly. Fully wound and only in the movement holder, no dial or hands, I let it sit untouched for two days. Both nights it advanced the date. The second night it might have been just shy of fully advanced. Seemed as though I fixed it, so I reassembled the watch. Three nights in a row the date did not advance. Once I pull the crown it does. So you might think that it's the dial interfering, but here's the weird thing. If I advance the date during the day to 11:57p and watch it get to 12:00:30a the date flips with gusto. So here's what I'm thinking and could use your council. I installed a new Swiss mainspring. I used Moebius 8217 braking grease on the barrel walls. It seems to wind quite a bit before slipping, but does slip.  I've read that the 7750 really needs Kluber p125 as a braking grease.  Do you think it just doesn't have enough power after a few to several hours of sitting before the date change? Here are the TG numbers after service:  Rate +1s/d,    Amp 301,    BE 0.0ms
    • I've managed with the ones I have but 1.8 mm would be better.
    • Parts weren’t readily interchangeable when this watch was made, and almost every part was adjusted by hand to fit the rest of the parts in that specific watch. That said, it can save time to harvest a part from a donor movement so you can modify it to fit a similar movement, rather than try to make the part from scratch.  With that in mind, it is possible that the click from this watch was removed for use in another watch. I doubt that the other missing parts were taken for use as donor parts. The cannon pinion would be removed properly, rather than snapping it off with the centre wheel arbour and pin inside it.  The Maltese cross stop works were probably removed by a lazy or less knowledgeable watchmaker servicing the watch.  It is very common to encounter otherwise functional watches (including very high end pieces) that are missing their stop work because a previous watchmaker didn’t know how to set it up when reassembling the movement, or was too lazy to bother and knew that the customer would probably never notice.  It is possible that the stop work parts were taken to be fitted to a watch that was missing them.  Best Regards, Mark
    • I posted a link to another video where he takes it a step further and uses the pins to set and adjust rate as well as positional error.  Alex doesn’t manipulate the stud angle after he pushes it in but I find it makes a difference in the spring concentricity and bend.  Amex also doesn’t use the pin manipulation to adjust positional discrepancies.
