Hello,
It's been a while since I've posted but I have an issue that's perplexed me! About ten months ago, I repaired and serviced a rare ETA 2832 movement with a day date calendar mechanism. The watch worked fine until recently when the day wheel advanced half way and then got stuck. Having had it back on the bench and done a partial strip-down, I have re-engaged the day wheel, which now turns freely through all days in the crown/stem corrector position (as does the date wheel when turning in the opposite direction) but when moving the hands forward through 24 hours, the date wheel advances but the day wheel will not. I have carefully examined the day jumper mechanism and note that as the calendar wheel rotates and the arm engages the teeth and rotates the date wheel, nothing seems to be engaging to move the day wheel forward. I have added a few photos which may help to identify the problem. I have annotated with a red arrow, the lever which I think is supposed to advance the day wheel but doesn't engage at the calendar wheel teeth (if indeed this is what it's supposed to do). Any ideas of what I may have missed here?
Thanks
I don't know the answer here, but should have been posted in "Watch repair questions". That is the only section where you can rate and flag correct answers.
Thanks jdm.
Moderators, please feel free to delete this post. I have moved it to "Watch Repair Questions". Thanks.
  • Similar Content
    • By the way, I opened my watch, looked under a magnifying glass, there is simply no grease, the screws are without traces, the slots are intact.I think it's just a matter of maintenance.there are no rotor marks on the body. And to remove the strap from yours, just press on the 1st side,and slightly move the strap, then on the other side and it will come off.
    • Hi My name is Chris. Just started trying to learn about watch and clock repair as a result of repairing my fathers old 1890s police station clock (about a year ago). The clock was Ok, but having graduated to pocket watches and then wrist watches, despite the really excellent stuff on Youtube, I am struggling a bit.  As a retired engineer, I find the engineering exquisite, but a bit on the fiddly side.  I have done a few practice watches with a little success but failed a few, but have had success with Seiko 7005s, 7009s etc, but have just attempted a citizen 5430.  Nightmare.  My wife thought I had found religion as I spent so much time on my knees with my eyes to the floor looking for springs.  Got through that and found that the balance is shot.  Trying to source one or something that will fit from the citizen range has me totally perplexed.  Tried Ebay, Cousins etc without luck.  Any advice as to alternatives that will fit or alternative sources would be gratefully received.
    • I have only been a member for six years & I have found this a very friendly forum although I don’t have anything to do with watches not because I don’t like watches but because I have gout in both hands so my dexterity isn’t very good, I restore torsion clocks & occasionally other antique clocks also at 72 my eyes are not what they used to be, that is why I only post on the clock forum & the lathe forum mostly . As others have said Mark it is much appreciated that  you are willing & able to do this. very many Thanks Dell
    • Ah, this is brilliant, thank you very much!
