Hi
I'm for ever been corrected for using the wrong words for watch parts. the book iv'e got is from the 1950s so i suppose words change.
Can any one suggest a site or book or download were the words for watch parts are up to date.
A diagram with the name connected to the parts would be nice.
That's what i've got now.
I guess i should be using the right terminology.
thanx
gary
You should have posted in "chat about watches".
Check attached service sheets, parts are named in multiple languages. You can also buy CDs of (old) watchmaking books for cheap on Ebay, parts name don't change, there can be some regional variation whci doesn't matter much.
3400_ETA 2390,2391.pdf 2824-2.pdf
  NOT TO WORRY;    it is a problem  caused by the internet.  and authors.    like "crown gear" or castle gear or "hunting case" or just "hunter".   we can live with it.   vin  p.s.   i like the above posted "time zone watch school"  closssory.    spelling is also a problem with the older guys.
    • The ones I have opened also do not have a pry point , hence the reason for the tool. The watch is clamped in the tool and a blade is screwed into the seam, the blade being chamfered lifts the back then the screw shaft is turned and the back comes off have a look on Ali express for case back removal tools
    • I don't think I need to know more about the Orient watch question, so please don't write anything related to the topic, but if you know where I can buy the watch's jewels = rubies and gems shock protection, I would like to know.
    • It's an exhibition back so no access as you suggest.
    • I have no experience with this watch, but looking at the pictures from the ebay listing linked above, it looks like the outer metal bezel at the back of the watch may not be part of the case proper.  It looks like the watch and strap are sandwiched together, and an inner case may push out of the rear bezel towards the front of the watch.  A case style similar to the Roamer watches where the crystal, movement and caseback pushed out through the back of an outer bezel, only in reverse - this one may push out towards the front.  To test this, you would need to hold the watch, dial down, supporting the dial side of the watch around the edge of the bezel without touching the bezel itself. Then push down carefully on the inner metal ring you can see at the back of the watch. I’m speculating here, proceed at your own risk. Hopefully someone with hands on experience of these watches can chime in! Best Regards, Mark
    • Thanks, Mark. That's the kind of reassurance many of us wanted to hear! Yes, life is unfortunately unpredictable, and it would be a shame if the many dedicated WRT: ers became stranded if, god forbid, something happened to you and WRT stopped working.
