There's no way really other than checking the escapement functions. Some forks have a significant gap at the back where the jewel sits, some none, generally somewhere in between. As even a move of 0.01mm will have a real impact on performance there's no shortcut.
Luckily it seems few forks get 'adjusted' willy nilly as it requires heating up, on the other hand I think every American watch with eccentric bankings I've seen has had the bankings put in the weirdest positions.
You can get fluttering, that is where the pallets escape to quickly from the teeth of the escape wheel, causing very little movement from the pallets, normally caused by a chipped pallet stone or pallets set in correctly.
@oldhippy! So am I correct thinking that, at one extreme the fork flutters( observable when balance removed, provding power ), at other extreme we get escapement locked up, ie; as we nudge the fork, it jumps to left/ right but will not let a teeth escape.
Therefore, the correct pallet position is somewhere in between the two extremes.
@nickelsilver  am I correct thinking that, at one extreme, improper pallet position can produce unhealthy large ampliude.
Both gentleman thanks for advices.
If you have an advanced Witchi timer you can also look at the noises the escapement makes with a resolution of 20 ms. It will give you in that view also the amplitude for both sides of the balance wheel movemnts. If they differ more than 10 - 15 degrees  you also have an indication for an issue with the depth of the palletstones. If you see a lot of jitter on the trace mode, also an indication of an issue with the pallet fork/stones.
Most simple, take your microscope at 20 - 40 magnification and look at the interaction of the palletstones with the teeth of your escape wheel. Quite often it is very clearly visible if the depthing has shifted of the stones.
br
Ron
    • By the way, I opened my watch, looked under a magnifying glass, there is simply no grease, the screws are without traces, the slots are intact.I think it's just a matter of maintenance.there are no rotor marks on the body. And to remove the strap from yours, just press on the 1st side,and slightly move the strap, then on the other side and it will come off.
    • Hi My name is Chris. Just started trying to learn about watch and clock repair as a result of repairing my fathers old 1890s police station clock (about a year ago). The clock was Ok, but having graduated to pocket watches and then wrist watches, despite the really excellent stuff on Youtube, I am struggling a bit.  As a retired engineer, I find the engineering exquisite, but a bit on the fiddly side.  I have done a few practice watches with a little success but failed a few, but have had success with Seiko 7005s, 7009s etc, but have just attempted a citizen 5430.  Nightmare.  My wife thought I had found religion as I spent so much time on my knees with my eyes to the floor looking for springs.  Got through that and found that the balance is shot.  Trying to source one or something that will fit from the citizen range has me totally perplexed.  Tried Ebay, Cousins etc without luck.  Any advice as to alternatives that will fit or alternative sources would be gratefully received.
    • I have only been a member for six years & I have found this a very friendly forum although I don’t have anything to do with watches not because I don’t like watches but because I have gout in both hands so my dexterity isn’t very good, I restore torsion clocks & occasionally other antique clocks also at 72 my eyes are not what they used to be, that is why I only post on the clock forum & the lathe forum mostly . As others have said Mark it is much appreciated that  you are willing & able to do this. very many Thanks Dell
    • Ah, this is brilliant, thank you very much!
