If you’re like me, taking apart you first ETA calibre 2472 and feeling somewhat intimidated after having removed the case back lid looking down on the automatic works, then you will likely appreciate this post.
By the way, except for the oscillating weight itself, the automatic winding device is identical for the following calibres:
ETA 2450, ETA 2451, ETA 2452, ETA 2453, ETA 2454, ETA 2472, and ETA 2474.
My only other experience of ETA’s automatic winding devices comes from calibre 2824-2. So, looking down on the oscillating weight of the ETA 2472 and not seeing a screw holding it attached to the automatic device framework, made me think the parts had somehow been riveted together and probably were inseparable. Having removed and looked at the back of the automatic device framework I could see that the oscillating weight was indeed attached with a screw or at least something that reminded me of a screw. Its slot was very thin, and it sat in a large jewel! No way I was going to try to remove it without knowing for sure it could be done and how it should be done, especially as this watch wasn’t mine but my brother’s who’d trusted it to me for an overhaul.
My first thought then was to try to remove all wheels without touching the oscillating weight. After having looked at the device for a good long while, I realized I wouldn’t be able to remove a single wheel before separating the oscillating weight from the framework. So, I decided to be patient (hardest part of watch repairing), put the parts away for now and research the Internet. I Googled “eta 2472 how to remove oscillating weight”. The first hit was “Untitled - OM-Mechanics”, a PDF document. Well, I wasn’t feeling very optimistic but lo and behold, there it was, in full detail!
Anyway, the PDF is pretty poorly scanned, and it isn’t all that easy to read the part numbers, so I decided to make my own picture guide for disassembling the automatic device of this ETA calibre 2472, and that’s what follows next:
(Eventually, I’ll publish a complete ETA calibre 2472 service picture walkthrough. If interested, you’ll find a link to it in a future post in this thread.)
y4mNG7T3hc2wx-BrNW_p-UKsFoJ3qY3kcnQ8t2nf
y4m-Wy-FaEKV502JEboBA42W3FV0CQH3Sqhykyp2
y4m8V4XAxJOEuWIrhNSLixR_hH_4SGRW0_7tw75c
y4mg_Jo1N2VNLw_wm_l8HvrOvGoYi2BhGNMRmvZ6
y4m0mrQnBALSfak_1Lf3ZI2y4VhXEHwaoVPZ-CBs
y4mWnWnSkUMkG45cNrJGmxX3oJ2unKWHBO3CdBV6
y4m8y_Xx6YQ-s0TSXmrCZMp0PFc0NATto57eCGA5
y4mjxi0-1UviUaPUJRXzRxbyHbUEhQcv6XewiFYi
y4mQnW1fb36gZfPa6N1YsCHGJOOykhdtN4Vm3Qxr
y4mE74Nm2rERDIib2gTcvuca_MI8fXM_gkrCj6je
y4mpsxbxz34M2AvNK1RAad8j2yLcA1i55Z_m_jWH
y4mNx1dvF0QPwe0I8tsKfk6dZcsCYWIKhGYbsrC6
y4mA5i7kEl2nLc78Yw6GvMQqyIgawr-69p0lBw6Y
y4mlDyBECIohtaSuUfatORkJ4KPPUXsI8wuNrvgk
y4mW-YOrWyQyEQHH7GTAFkMR8xP3LAvSEUnOh38N
y4mhIxfZz7psKR2-05tayOfWZ7djSB52tlQWf64i
y4mjgP_OqVlx8xqlLenxtiZRotgdra3vJiHWzLVj
y4m0Mm4W-44R6uky-Tsxo5LBK1hwqD_8w7m2i1sS
y4mYLaoQMmEgbEkwRXRUTk3nO4GJShlG9Ggbx2pO
y4mk9oWAlKfCs0ksk3PC64A9ZLerZrVOv8e8ParP
y4mNeK9rqje8W-aftdGRRsu4R5JF-nKtixscY2B5
y4mxQzudmzob-0pTBGUDx0DM1TuywrcxTLgnn5EP
  • Thanks 4
2 hours ago, Nucejoe said:
Shouldn,t the two screws 51.134  come in darker color( gun metal)?
I am not sure but wasn,t there a polymer washer on the screw 51.498?   Do you find it on pdf?
I don't think so. They do on ETA calibre 2824-2, but not on calibre 2472 (obviously!?).
No, and no!
Yes those auto systems are quite different if you're used to 2824/2892 stuff. Amazingly robust though, I rarely need to do more than clean them. The date mechanisms from that era will really throw you for a loop, but generally instantaneous change and again they work and work and work. Good to take photos as they can be unintuitive in function.
If there is excessive up and down play in the rotor you need to replace 51-498 and the gear which is a press fit into the rotor.
Bodge alert!! You can also address this problem to some extent by reducing the height of this post circled below. Only a little bit mind or you risk the rotor hitting the main-plate. If this happens you will need to remove some metal from the bottom of the rotor, usually the edge but in some cases even on the inner portions.
Anilv
To add to my post above, if you have tools which can cut the correct angle on the bottom of the automatic bridge this will also close up the clearance, in fact this is better but acheiving the correct angle is crucial.
Anilv
edit.. just realised yours has a jeweled hole.
Edited by anilv
I have just finished a clean and rebuild of a 2472. I needed to change the calendar date spring which is U shaped. The watch had not run for over 20years and is now keeping reasonable time. The calendar date wheel sometimes only flicks half way between dates. A gentle knock will flip the ring to the correct position. I have checked  the spring dims and all seems okay. Any advice would be very welcome. Its a great watch and good to have in my collection.
Check date ring teeth and date wheel finger for wear. Problem can be there, not with the spring.
You must lubricate the jumper for the date disk. Almost anything will do, 8200, 8300, Jismaa, D5, HP-whaterver, your choice. Put a bit, advance 5 days, a bit, 6 times. Can make all the difference in the world. Of course also the pivot point of the jumper and the contact point of spring on the jumper.
It can work fine after cleaning with no lube then get pissy a few days later.
It may be that the spring is to weak to handle decades of wear, or there is damage to the disc teeth as JDM said (this does happen, burrs develop and drag). Try the lube and see how it goes.
  • 5 weeks later...
  • 5 years later...
4 hours ago, Knebo said:
I know! But it didn't budge (sideways) even under quite a lot of pressure.
Some penetrating oil on the post, let soak over night.
Best to hold it in a long nose pliers & turn about the post, so you wont exert any force on post, so to avoid breaking it off.
This is one instant that slight damage from Coca Cola can affect reverses.
Screwdriver in the slot wont work if its stuck, perhaps some rust.
Good luck
Edited by Nucejoe
Auto correct typo
  • Similar Content
    • HWGIKE#57 Valex FEF 190 15 jewels Swiss lever full service and repair This one was waiting for a balance staff replacement in my cabinet parts and case cleaned up with a new balance staff and a 4th wheel as the original 4th wheel had a broken pivot for the off center second hand. I never attempted a balance staff replacement before however I received a Bergeon Molfres (i was hunting it for about 2 years) and with the help of it I managed to remove the old staff and riveted the new one in. It also received a new MS, crystal and the hole for the MS arbor was also tightened. With the new MS now it has an acceptable performance meaning that the amplitude goes up to 280 fully wound, has an acceptable beat error and I have the two nice lines but only dial up, dial down is not as nice and I could not figure out as why. I have the two lines but the amplitude is dropping to around 230 and the lines are a bit hairy. Both dial up and dial down the lines just go up and down without seemingly any pattern. I cleaned the movement two times, and then a 3rd time pegged out the main plate and train bridge holes but made no change. Both the HS collet and the roller table was too lose on the new staff... I did not count how many times I took the balance cock off to sort out the HS collet, the roller table and the beat error, somebody before me also shortened the HS by pushing it out a bit and it seems every time somebody is messing with the end of the HS the protruding bit is most of the time twisted bent etc. This one was probably one of the most challenging repair and service. I might take the new MS out and clean it lubricate it as I just pushed the new one in to the barrel from the retaining ring. Plus started to re-read the theory of the escapement and how to analyse the graph on the timing machine: Greiner Chronografic Record manual. I am also thinking to put the watch on a 24 hour long run with the eTimer SW it once helped me to figure out what was wrong with a watch. There is an interesting part of the Greiner record manual talking about the pallets and the end shake of the balance and pallet staff. Maybe this is my issue? Who could that possibly identify? After a few years now I am still without a clue how could watchmakers make parts I can only see with my microscope or how could/can they carry out complicated services impossible to do.. real magic..... .... ..... before I sent this post while the pics were uploading I had an idea, i was browsing the possible outcomes on the timing machine I had one for magnetism..... so I demagnetized the movement and it is not hairy now.... two really nice lines 0.2 ms beat error still a bit wavy, but a lot lot better..... argh....
