Great job and walkthrough, Don! Hope a new case come along and you can proudly wear this new restored/serviced watch!
Cheers,
Bob
Eventually it all snapped shut with a deafening report!
Just a thought.
I've had a couple like this myself Will, but always managed to close them with my cheap hand press. What I would say is always make sure that the die on the crystal side is only in contact with the case, then give it the death grip! :)
Definitely. Always work as long as the case and back are properly positioned! As the wife said, position is everything...she is learning watchmaking, don't get me wrong! :)
Edited by bobm12
Thanks for the kind words and encouragement, guys. :bow:
I tightened the press beyond what I was comfortable doing it, but maybe I'll have another go and take it further. I did manage to mar the new crystal a bit with the die by NOT doing what Geo said. On subsequent attempts I put the case in a case holder so that the crystal was not touching anything. I may as well go for broke before buying another case. I'm a little short of funds after buying the two crystal presses.
Don
  • 4 weeks later...
That was an awesome post. I bought an old Caravelle a couple of months ago for $5.00. It has a beautiful green dial. I can't wait to get it running and I will post some pics. Thanks.
Thanks, Scottster. I'd be curious to see your Caravelle. Is it the same movement?
No. It's a 1906. I bought it for $5.00 on eBay. I tore it down, cleaned, serviced it. After reassembly the minute and hour hands wouldn't move. I have a new driving wheel and pinion coming from Oldswisswatches.
It's interesting how you put the dome over your timer. I have a timer coming. The same one you have.
Beautiful watch. My case for the caravelle is pretty bad. I'm going to try to clean it and put a new crystal in it. I don't have any experience with crystals.
It is a beautiful watch. Thanks for the pics.
I hope you get it running with the replacement parts. I've messed around with two AS movement and I like them.
I just put a plastic movement holder dome over the movement on the timer. My home is super dusty so I try not to leave any parts uncovered for long. I've been meaning to make a proper base like the Horotec dust cover on this page. It's a great idea, but not worth $40 to me.
My case is beat up pretty bad too. In addition, I could not get the case back to snap on and I eventually broke the stem while trying. Fortunately Caravelle's are pretty easy to find cheap, if you're patient, so I hope to be able to wear the watch soon. Setbacks are demoralizing, but part of me is actually excited when I encounter a problem, because it's an opportunity to gain experience. Sometimes you win, sometimes you learn.
Thanks for the nice comments.
    • I doubt it is due to lack of amplitude.  My 7750 - which I haven't serviced yet because the numbers were OK (and I am still scared of chronographs!)- has no problem flipping the date with an amplitude closer to 250º On other movements I have had issues where the plate(s) that go over the calendar wheel interfere.  I did an FHF ST 96-4 last week where there are 2 tiny plates plus a larger plate that hold the calendar wheel in place and I had real problems getting the calendar wheel to snap around nicely.  Lubrication on the points of the teeth of the calendar wheel and making sure the small plates were aligned properly was the solution there.
    • Well I spoke too soon. Here's where I am now with this issue. I replaced the date jumper and all seemed to function correctly. Fully wound and only in the movement holder, no dial or hands, I let it sit untouched for two days. Both nights it advanced the date. The second night it might have been just shy of fully advanced. Seemed as though I fixed it, so I reassembled the watch. Three nights in a row the date did not advance. Once I pull the crown it does. So you might think that it's the dial interfering, but here's the weird thing. If I advance the date during the day to 11:57p and watch it get to 12:00:30a the date flips with gusto. So here's what I'm thinking and could use your council. I installed a new Swiss mainspring. I used Moebius 8217 braking grease on the barrel walls. It seems to wind quite a bit before slipping, but does slip.  I've read that the 7750 really needs Kluber p125 as a braking grease.  Do you think it just doesn't have enough power after a few to several hours of sitting before the date change? Here are the TG numbers after service:  Rate +1s/d,    Amp 301,    BE 0.0ms
    • I've managed with the ones I have but 1.8 mm would be better.
    • Parts weren’t readily interchangeable when this watch was made, and almost every part was adjusted by hand to fit the rest of the parts in that specific watch. That said, it can save time to harvest a part from a donor movement so you can modify it to fit a similar movement, rather than try to make the part from scratch.  With that in mind, it is possible that the click from this watch was removed for use in another watch. I doubt that the other missing parts were taken for use as donor parts. The cannon pinion would be removed properly, rather than snapping it off with the centre wheel arbour and pin inside it.  The Maltese cross stop works were probably removed by a lazy or less knowledgeable watchmaker servicing the watch.  It is very common to encounter otherwise functional watches (including very high end pieces) that are missing their stop work because a previous watchmaker didn’t know how to set it up when reassembling the movement, or was too lazy to bother and knew that the customer would probably never notice.  It is possible that the stop work parts were taken to be fitted to a watch that was missing them.  Best Regards, Mark
    • I posted a link to another video where he takes it a step further and uses the pins to set and adjust rate as well as positional error.  Alex doesn’t manipulate the stud angle after he pushes it in but I find it makes a difference in the spring concentricity and bend.  Amex also doesn’t use the pin manipulation to adjust positional discrepancies.
