In another thread I mentioned sometimes making bushings to repair a watch with a broken or missing rubbed in jewel, and as I had one to do today I thought I'd show the process. There are tools for opening and closing the settings, but they don't always work as sometimes the metal just doesn't want to be flexed back an forth like that; on this piece, a LeCoultre 409,  the bridge is quite thin where the jewel sets (0.30mm), and is german silver, and the walls of the setting just crumbled when trying to close and looked horrible.
I determined the outermost diameter of the original setting was 1.30mm and had a jewel with the correct hole size and an outside diameter of 0.90. The plate was glued to a support and centered on a faceplate. My setup is pretty "fancy" but it's the same as a regular watch lathe faceplace, just bigger, and I have the advantage of using a scope in the little jig borer to check the centering rather than the old school wobble stick technique. Once centered, the bridge with the bad setting was installed, and it gets put on the lathe. I bored the hole to 1.29mm, then made a bushing with an outside diameter of 1.30, and hole of 0.89. This was done with a cross slide in the watchmaker's lathe, the hole being bored not drilled, to ensure exact size and concentricity. The wheels in this caliber have very very short pinions, so any error in alignment between the jewels could easily tilt a wheel enough to crash somewhere. A rather large bevel was cut on the bushing to simulate the rubbed over area of the original, everything pressed together like it should, and is pretty much invisible. While perhaps a bit invasive if working on a museum piece by Berthoud, it's a solid way to approach this sort of repair, and down the road if there's ever a problem with that jewel again, easy for the next guy to replace.
  • Thanks 2
Thank you very much for posting that.
Can you show a picture of the set of gauges you used for measuring the diameter of the hole you bored as that looks to be something very handy, although I'm guessing they have a heft price tag to go with them.
They are made by Cary (Swiss), new price around 1200 francs/dollars for a set of 50. In 0.01mm increments... I have from 0.05mm to 3mm, definitely didn't buy new, but even used they go for a few hundred per box; took a few years to track down and accumulate my sets. There are inexpensive sets from China that don't have the handy little handles and are quite accurate. When doing precise hole work they really are a must.
Thanks, I have seen smaller sets for watch pivots, but never a set for largers sizes like that, something else for me to keep an eye out for.
Hi Nickelilver, Would you furthure comment on keepin the integrity of the piece.
Was this more of a lesson, or any reason why replacement wasn,t with another rub-in jewel.
Where would you draw a red line for a collector?
Thanks in advance.
Thanks in advance.
The setting on this one was compromised, the metal just couldn't take being opened and then reclosed. I had a jewel in it, but with about half the retaining metal flaked off it just looked horrible. For me doing this sort of "false setting"is better for a nice piece like an old Lecoultre than simply opening the hole up to take a friction jewel- not to mention the bridge on this one is so thin that a friction jewel at around 1.30mm diameter would almost certainly be too thick, as well as unsightly (way too big). On a very rare, unique, valuable museum type piece the name of the game is generally conservation, so one wouldn't even attempt the jewel change, just clean everything up and conserve it. When a customer wants functionality it's necessary to be quite clear on the difference between repair (what I did here) and restoration, which in this case might have gone as far as remaking the entire bridge. That's a far fetched scenario, certainly for a serially produced watch movement such as this. A replacement bridge might be sourced but these old movements don't always interchange like one might like... The cans of worms are many when getting into parts fabrication, but generally price gets everyone on the same page.
Thank you for your response and showing Inspiring work.  I do cheat a little in restorations, may replace a part even for unsightly looks, needed a standard for grading my work.  Best wishes. Joe.
What material did you use to make the bushing? And once made, did you friction fit the new jewel in the bushing and then friction fit the bushing in the plate.
I used german silver (nickel) bar, to match the bridge color. Yes, fitted the jewel to bushing, then bushing to bridge, though it works the other way too. I'm pretty sure supply houses still offer assortments of nickel bars, they are very handy!
Will try to find...5mm diameter?
That's a good size, I think the assortments go from around 1 or 2 up to 5 or so generally.
