Ansonia chime issue
mrxmttr
So I'm working on an Ansonia clock. Re-bushed, flipped the great wheel over and it is now running. The problem is I can't seem to get the chime working. I suspect that I may have put a part in the wrong way but for the life of me I can't see where or why. A picture is attached. The only number on the movement is 89 stamped on the bottom right of the back plate. Thanks in advance for any help.
I should add that the gear train does spin but won't stop. I know that is not much info but I don't know what else to add.
Update, it appears that it is probably a timing issue with one of the gears. Anyone familiar with how to set timing properly
Edited by mrxmttr
add more information
  • 5 months later...
When assembling the strike train, position the wheels so that (a) the hammer tail has just dropped off a lifting pin; (b) the count lever is in the centre of a deep slot in the count wheel; and (c) the locking lever is in the slot in the locking wheel. Keep the spring clamps on until you’ve got the wheels in the right positions. Good luck!
Phil
Strike trains require sychronization of stopping pin/lever, warning pin, and lifting pin on strike wheel with the hammer lever.
Add to that the countwheel (if there is one) is eccentric and needs to be set at the 12 strike notch (largest notch on countwheel).
Rack strikes were an advancement to countwheels.
The french use a pivot mounting bracket on the back plate such that one can adjust the strike wheel so the hammer lever will fall off exactly when the strike train is about to cease.
Warning pin should be set between 1/2 to 1/4 turn away from the warning lever.
Trail and error and a lot of cursing.  It also helps to set up the strike train as best as possible before plating.  On thin plate clocks pivot up the time side and loosely add the plate mounting nuts so ur only worrying about getting the strike pivots in.  Hope that makes sense.
    • HWGIKE#57 Valex FEF 190 15 jewels Swiss lever full service and repair This one was waiting for a balance staff replacement in my cabinet parts and case cleaned up with a new balance staff and a 4th wheel as the original 4th wheel had a broken pivot for the off center second hand. I never attempted a balance staff replacement before however I received a Bergeon Molfres (i was hunting it for about 2 years) and with the help of it I managed to remove the old staff and riveted the new one in. It also received a new MS, crystal and the hole for the MS arbor was also tightened. With the new MS now it has an acceptable performance meaning that the amplitude goes up to 280 fully wound, has an acceptable beat error and I have the two nice lines but only dial up, dial down is not as nice and I could not figure out as why. I have the two lines but the amplitude is dropping to around 230 and the lines are a bit hairy. Both dial up and dial down the lines just go up and down without seemingly any pattern. I cleaned the movement two times, and then a 3rd time pegged out the main plate and train bridge holes but made no change. Both the HS collet and the roller table was too lose on the new staff... I did not count how many times I took the balance cock off to sort out the HS collet, the roller table and the beat error, somebody before me also shortened the HS by pushing it out a bit and it seems every time somebody is messing with the end of the HS the protruding bit is most of the time twisted bent etc. This one was probably one of the most challenging repair and service. I might take the new MS out and clean it lubricate it as I just pushed the new one in to the barrel from the retaining ring. Plus started to re-read the theory of the escapement and how to analyse the graph on the timing machine: Greiner Chronografic Record manual. I am also thinking to put the watch on a 24 hour long run with the eTimer SW it once helped me to figure out what was wrong with a watch. There is an interesting part of the Greiner record manual talking about the pallets and the end shake of the balance and pallet staff. Maybe this is my issue? Who could that possibly identify? After a few years now I am still without a clue how could watchmakers make parts I can only see with my microscope or how could/can they carry out complicated services impossible to do.. real magic..... .... ..... before I sent this post while the pics were uploading I had an idea, i was browsing the possible outcomes on the timing machine I had one for magnetism..... so I demagnetized the movement and it is not hairy now.... two really nice lines 0.2 ms beat error still a bit wavy, but a lot lot better..... argh....
