Repair Of A Carriage Clock
Look for Citizen 5400, 5410, 5420, 5430 & 5470 as members of a family. 5400 is likely to be the base caliber. Balance complete of any of above calibs would fit the others. Normally most parts of the base calib interchange with all members of the family. Regs
I measured the Reform, and yes it is >50mm; somewhere between 50.5 and 50.7mm. This is measured using pieces of bar stock resting on the flats of the bed, under the lowest point of the faceplate. Still not enough for clearance on dia. 4" though. If the axis of the headstock were centred over the bed, then the channel in the middle would allow a fraction more clearance, but it's not, not on the Reform anyway. Buy low, sell on ebay!
By nickelsilver · Posted
WW is 50mm exactly. Levin, Derbyshire, Leinen, Boley Lorch and I'm sure most others making machines based on the WW standard are all 50mm. Marshall/Peerless are 2", or 50.8mm height. Many lathe beds are slightly relieved in the center, so it could be possible to swing something a little over 100mm. More likely is the auctioneer had measured with a tape measure and called it 4" when it's like 98mm. -
Welcome to the forum. The Citizen 54** isn't the best range to be learning on due to limited information and parts. What's wrong with the balance and can you post photos.
Interesting. It also seems strange that it’s only the jewel on the top of the balance that has the grove and not the one on the bottom. I guess maybe one of them got replaced at some point. I’ve never used Fixodrop but I think it’s something I will look into to. Can I just ask how you use it when oiling the cap jewels?
