I fell in love with old pocket watches about a year ago. Decided to try to take them apart to clean and reassemble hoping that they would work again. It's a real challenge,  the parts are tiny and putting them together requires patience and ability.
I live up in northern Quebec and enjoy the outdoors.
    • Hi. It’s either riveting or welding . I have seen some small home made welding tools on UTube at times may be I should have a go at building one, they are small spot welding machines. Suitable for the likes of these type jobs.
    • Hi watchweasol, yes that is a way of doing it I suppose, I have a pair of mainspring hole making pliers on their way off eBay, the ones with the different shaped punches. I may be able to use them to make a hook.
    • Hello everyone, Glad to be here.
