Taking this balance from the cock, I managed to get the hairspring coils tangled.
Does anyone have a technique to untangle the coils?
Last time this happened, I tried to pull the coils apart with 2 pairs of tweezers - accidentally released the pressure on one pair .....
and I'm still looking for a new hairspring on a (very very hard to find) Universal Geneve Cal 267
This is a cheap Poljot - but I'd still like to figure it out.
Thanks
Mike
If you're able, remove the hairspring via the collet, this frees up the weight of the balance.
I find a combination of either 2 #5 tweezers or one of those and an oiler with a 10X loupe works reasonably well, the key is patience, if you feel yourself getting impatient walk away for a bit.
I'd just put the hairspring back on after tightening the collet. I thought I was suddenly getting great amplitude and no beat error before I realised the collet was loose !
I put it on a balance tack to work on, but that didn't seem to help.
I recently bought a stereo microscope which makes fiddling with hairsprings so much easier.  I always found it very difficult with a 10x loupe as the working distance is so small.
I was thinking of pinning it down, then running a fine oil round the coils starting from the collet.
Pinning down and running a needle through circles as you say, works, I have done it many times, but you may find that stud  hinders untangling specially as you get to outer coils. I always unpin and seperate the stud from HS. Like so                                          Remove HS off of the wheel. Re instal stud back in stud holder hole, tighten its screw, push on the sharp point of micro pin with flat face of a thin screwdriver and grab the thick end of the micro pin in tweezers to shake it loose, repeat several times pin will eventually loosen and come out.        Proceed to untangle. You may find circles out of round /center/ unlevel.   Removing the stud greatly increase chances of success.    Good luck
Hi Been there and still have to repair the last one. The key is patience if frustrated walk away and try later. All the techniques you have been quoted are spot on just follow the advise, but remember  PATIENCE.  good luck.
Most adapt their own methods. I find using a microscope & fine tweezers & a needle works normally. But manipulating hairsprings is extremely difficult because too much manipulation will result in the spring breaking. I speak from experience.  A donor movement is the best route if possible, finding the correct hairspring replacement is also difficult.  This in many ways is why horology becomes compulsive.
I know this is now obvious but the handling if the balance and hairspring requires the utmost care and attention. Watch Marks vids and see how a pro treats this area.
I usually let the balance wheel hang while the stud is still attached to the cock (which itself is mounted on a balance tack). Then I run a needle through the spring while holding the balance wheel steady.
I have used a piece of paper with a small slit. Starting at the collet and moving the paper in a circle to follow the coil . This keeps the tangled part above the paper and easier to untangle with tweezers as you rotate the paper and move your way outward.
Thoughts?
Thoughts?
Genius! That's a great suggestion. I will need to try that.
Thanks, it worked for me and was the only way I could isolate the tangled part from the untangled.
I managed to get the tangle out without taking the hairspring off. I used a clean oiler and ran it outward from the collet. Then some fine tweezers to lift the coils. I have good a couple of kinks to sort out.
New balances are available from Cousin's for only £10 but I wanted to learn how to do this.
Thanks for to suggestions.
  • 2 years later...
Thoughts?
Could you describe this in a bit more detail? Do you mean you slot the hairspring collet into the slit of the paper and rotate the hairspring under the paper?
Also, how do you remove the hairspring without distorting the arms of the balance wheel, or kinking the hairspring where it attaches to the collet? I haven’t had good experience with lever type tools, or using a blade.
So far, I had hairsprings that started with tangled but still flat, to untangled but out of flat in multiple locations, to unrecoverable.
Edited by ifibrin
  • 2 years later...
Thoughts?
I just tried that technique and it saved the day on a little Longines 9L I have on the bench. That was extremely helpful advice. Thanks a lot!
Since posting this 5 years ago, my hairspring fixing has improved a lot.
I recently posted this in another thread, but it's worth watching (it's Henry B Fried)
    • HWGIKE#57 Valex FEF 190 15 jewels Swiss lever full service and repair This one was waiting for a balance staff replacement in my cabinet parts and case cleaned up with a new balance staff and a 4th wheel as the original 4th wheel had a broken pivot for the off center second hand. I never attempted a balance staff replacement before however I received a Bergeon Molfres (i was hunting it for about 2 years) and with the help of it I managed to remove the old staff and riveted the new one in. It also received a new MS, crystal and the hole for the MS arbor was also tightened. With the new MS now it has an acceptable performance meaning that the amplitude goes up to 280 fully wound, has an acceptable beat error and I have the two nice lines but only dial up, dial down is not as nice and I could not figure out as why. I have the two lines but the amplitude is dropping to around 230 and the lines are a bit hairy. Both dial up and dial down the lines just go up and down without seemingly any pattern. I cleaned the movement two times, and then a 3rd time pegged out the main plate and train bridge holes but made no change. Both the HS collet and the roller table was too lose on the new staff... I did not count how many times I took the balance cock off to sort out the HS collet, the roller table and the beat error, somebody before me also shortened the HS by pushing it out a bit and it seems every time somebody is messing with the end of the HS the protruding bit is most of the time twisted bent etc. This one was probably one of the most challenging repair and service. I might take the new MS out and clean it lubricate it as I just pushed the new one in to the barrel from the retaining ring. Plus started to re-read the theory of the escapement and how to analyse the graph on the timing machine: Greiner Chronografic Record manual. I am also thinking to put the watch on a 24 hour long run with the eTimer SW it once helped me to figure out what was wrong with a watch. There is an interesting part of the Greiner record manual talking about the pallets and the end shake of the balance and pallet staff. Maybe this is my issue? Who could that possibly identify? After a few years now I am still without a clue how could watchmakers make parts I can only see with my microscope or how could/can they carry out complicated services impossible to do.. real magic..... .... ..... before I sent this post while the pics were uploading I had an idea, i was browsing the possible outcomes on the timing machine I had one for magnetism..... so I demagnetized the movement and it is not hairy now.... two really nice lines 0.2 ms beat error still a bit wavy, but a lot lot better..... argh....
