How to remove this bezel?
Lc130
Hi All
I'm a beginner.  I've been unusually successful in bringing this AS 1950/51 back to life (just dirty and oily).  I now want to polish out the crystal scratches.  How do I safely remove the bezel so it's not impacted?   I've not done this before.  Bezel still twists and looks like there's a plastic ring underneath.
Do I just pry at that notch with a screw driver?  How do you get it back on?  This is not a necessity.  So if any risk, I won't attempt it.
Thank you
Charlie
You should use a case knife not a screwdriver.
Be careful when prying not to insert the knife blade too much or fiddle it around as you might break the parts inside/underneath the bezel. (usually there's either a steel spring wire part or a steel flat circle and they're a bit fragile).
Thank you!
12 minutes ago, saswatch88 said:
case knife or ebay has bezel removers for like $30 they work like a charm
No need to get a full blown tool if chances are it will be used 2 times in life. Especially on old watches rotating bezel are generally quite lose.
A Seiko style case knife is $2, I got all 4 just because.
i personally like the ones that are not hand held, simple because it limits the chance of slips which could damage a case. they have a 4 bladed one which os great because its lifts the bezel of evenly, which is best for bezels that dont have a little indent to get under it. the single bladed one is the same as what you posted, and you can change the blades.
On these, e.g. Seiko, just rotate a tiny bit until the spring will be pushing the bezel up and locate the spot with most light. You will be able to insert then a lot more easily.
    • Someone just made me aware that no images are showing in my post ( ). Could someone with the proper permissions check this? I believe the images are ones I uploaded to the site, but they could also be ones I shared from my OneDrive, which had an issue some time ago.
    • I would have jumped all over that set if it had come across my Ebay search results !  Very nice , well taken care of. I probably buy 10+ staking sets a month for my restoration hobby and think you found a very nice set, at a great price that should last you a lifetime.
    • Here's another old tool that doesn't get used much, but has saved me many hours and headaches when it has been.   This is a depthing tool, but quite special. The depth can be set (or measured) very precisely with the micrometer to the right, with a direct reading of the actual center distance between the wheel and pinion. It originally came with a set of the little plates in the slots to the right that take the pivots (first pic), most of mine are missing but they can be made when needed. The section that takes the right hand wheel can be adjusted in height. And it can be set on a profile projector if needed to check things. This one is marked Tripet, but most I have seen are marked Hauser. All of them were made by a small company in La Chaux de Fonds (can't think of the name now).
    • This would be the case on a chronograph movement but the Ronda 515 doesn't have an AC contact. Here's an example of a Seiko movement with the AC Reset.
    • There seems to be a way to "short" the thing to what they call an AC Reset... Makes a bit of sense, only problem is that i have  to firstly re-assemble the movement.
