Hi I just inherited an ascot Krippl watch, it was manufactured in 2009 and was bought ten years ago in a u.k store, although the watch is ten years old all it needed was a battery. The watch is in excellent condition, someone once remarked to me recently the watch looked like cheap crap. I inherited another Swiss watch and the similarities to the ascot is uncanny, both are stainless steel backs and waterproof. The ascot watch was bought in a Lidls store. When I was in Berlin recently I never saw any ascot watches in a Lidl store. It's a pretty robust watch and has got the manufacture date and serial number on it. They are highly collect able as they are sold on e bay which was a complete surprise. So the person I had spoken to recently binned the ascot off didn't know what she was talking about as I did my research !
The value of a watch is truly a subjective thing. You may have grown up with a quartz digital watch that came in a blue plastic case with your favorite children's cartoon character on the face and cost $5 and to you, this watch is absolutely priceless and irreplaceable. Someone else may have inherited their grandfathers Rolex which turned out to be an ultra rare model worth nearly a Million dollars and they quickly sell it and pocket the money without a second thought. You'll also find people talk out of their posterior regions frequently and truly don't have a clue. One lesson I think you learned from this experience, knowledge is power!
Moving to the appropriate section, and may I politely ask you not to make every subject you post with the same title I will rename this one "Krippl watch" :)
Thanks for your understanding.
    • The ones I have opened also do not have a pry point , hence the reason for the tool. The watch is clamped in the tool and a blade is screwed into the seam, the blade being chamfered lifts the back then the screw shaft is turned and the back comes off have a look on Ali express for case back removal tools
    • I don't think I need to know more about the Orient watch question, so please don't write anything related to the topic, but if you know where I can buy the watch's jewels = rubies and gems shock protection, I would like to know.
    • It's an exhibition back so no access as you suggest.
    • I have no experience with this watch, but looking at the pictures from the ebay listing linked above, it looks like the outer metal bezel at the back of the watch may not be part of the case proper.  It looks like the watch and strap are sandwiched together, and an inner case may push out of the rear bezel towards the front of the watch.  A case style similar to the Roamer watches where the crystal, movement and caseback pushed out through the back of an outer bezel, only in reverse - this one may push out towards the front.  To test this, you would need to hold the watch, dial down, supporting the dial side of the watch around the edge of the bezel without touching the bezel itself. Then push down carefully on the inner metal ring you can see at the back of the watch. I’m speculating here, proceed at your own risk. Hopefully someone with hands on experience of these watches can chime in! Best Regards, Mark
    • Thanks, Mark. That's the kind of reassurance many of us wanted to hear! Yes, life is unfortunately unpredictable, and it would be a shame if the many dedicated WRT: ers became stranded if, god forbid, something happened to you and WRT stopped working.
