I am sorry if this upsets some people but I am curious. Does it bother you when you buy a high end watch (Omega, Tag Heuer, etc) just to find out it has a movement you could get in a lower priced watch? What is more important to you, the name, or the quality of the watch? If I get the same movement in an Invicta why but a Tag?
Ive written about this numerous times. Be careful....the tag and Oris lovers will pounce on you when you compare their $3000 diver watch to an invicta......they dont like being made out to be a fool. They will regurgitate the koolaid in a hearbeat. Stand by. As far as Omega....at least they do some secondary work. Ive seen the void on a 7750 between low to high be as much as 10 grand. Its nuuuuuuuts.
Sent from my SM-G950U using Tapatalk
This is a similar problem I personally have with Movado. There is an overall cheapness (in my opinion) to them. They are basically plain and featureless and use the most basic of quartz movements. The few automatics they offer uses the midland, though reliable ETA movement (2428-2). At least brands like Invicta know they're cheap! lol. When I think Movado, I'm never inspired with quality.
It's about branding. The same goes for many items such as cars ie a many Skoda's actually have a VW engine. Many watches have Eta movements which are owned by Swatch, Bremont brands its watches itself as British made but I noticed many have the Eta 7750 movement fitted.
Hi Clockboy  Its been going on for years, It was known as badge tecnology there are many watches/clocks out there using known makes of movements branded by others. Many movements we made under the eubauches stamp and fitted to a lot of brands. In the computer trade it happened as well, and as you mentioned the car trade, I once had a vauxhaul with an Izuzu engine, and a Ford capri with a german engine although the car was build in Dagenham Uk . Common practise.
Def not a fan of mavodos either. I read all about this at one point but basically (i think) at some point durring the 70s when the digital watch came on the scene the mechanical manufacturers were taking a beating. When the dust finally settled the only one left was eta who pretty much bought all the other manufacturers.
    • I have no experience with this watch, but looking at the pictures from the ebay listing linked above, it looks like the outer metal bezel at the back of the watch may not be part of the case proper.  It looks like the watch and strap are sandwiched together, and an inner case may push out of the rear bezel towards the front of the watch.  A case style similar to the Roamer watches where the crystal, movement and caseback pushed out through the back of an outer bezel, only in reverse - this one may push out towards the front.  To test this, you would need to hold the watch, dial down, supporting the dial side of the watch around the edge of the bezel without touching the bezel itself. Then push down carefully on the inner metal ring you can see at the back of the watch. I’m speculating here, proceed at your own risk. Hopefully someone with hands on experience of these watches can chime in! Best Regards, Mark
    • Thanks, Mark. That's the kind of reassurance many of us wanted to hear! Yes, life is unfortunately unpredictable, and it would be a shame if the many dedicated WRT: ers became stranded if, god forbid, something happened to you and WRT stopped working.
    • The case back is perfectly aligned to the case and has no provisions for a screwing tool. The T-Sport series has snap on backs.
    • For me the text looks too aligned and with no obvious way to grip as a screw back.
    • There’s no indents & there’s no little groove to pry it off anywhere! So I don’t know if it’s screw down or pry off 👍
