Wow, that is very expensive :)
Looks like a cheap riveted together model too. Better (older?) models use screws, and have indexable pallet holder pieces, for different pallet types. To be honest I've only used a single configuration..
Its not cheap tool in construction, just vintage. This tool makes re-setting pallets easy and importantly setting them accurately.
I have use it a few times now and can not fault it.
    • No mate. Sorry if that offends you! Also please don’t take threads off-topic. I thank you sir.
    • Thanks Mark I have uBlock Origin Lite add-on for my Windows Chrome browser, so I've never seen a single ad on this site ! It also removes all adds from Youtube - I couldn't bear to watch it without uBlock
