Without any research I guess the moment is a pin lever EB 8800 . A real work horse of a movement no jewels but incredibly robust but don't expect wonderful readings with a timographer etc.
It is a 866  the only other marks I can see is on the inside of the case 815477, i presume the last two numbers depict the year of manufacturing.
Debating if it should get restored, the movement is ok except its running like a steam train and the back cover and crown are down to the brass, a few scratches on the crystal and a new denim strap.  Not too much work I supose
Assuming the hairspring is concentric, and the balance pivots are still intact,  then the most likely cause of it running poorly is dirt, so yes, clean it, or get it cleaned and lubricate it and it will probably be fine.
Given the 866 series' simplicity of construction, I suspect you can get away with removing the balance hands and dial, and cleaning the rest without disassembly, a bit like a Timex. The ones I have looked at recently, I had to strip as there were parts that needed replacing, or in one case, I needed to construct one movement from a bunch of junk movements.
Donor movements are easy to pick up for a few bucks on ebay if it does require parts, but the single bridge design does make it a little fiddly to disassemble and put back together. Patience, a gentle touch,  and persistence pays off.
Thanks for the info. The hair spring does look a bit gummed up, I’ll remove it tomorrow and give it a clean to see how it performs before servicing
Sent from my iPad using Tapatalk Pro
Hair spring bent in various places and touching balance bridge, straightened it out a bit but still not right so I've ordered a new one from cousins
fiddly getting the pin pallet bridge back in place :chainsaw:
    • The ones I have opened also do not have a pry point , hence the reason for the tool. The watch is clamped in the tool and a blade is screwed into the seam, the blade being chamfered lifts the back then the screw shaft is turned and the back comes off have a look on Ali express for case back removal tools
    • I don't think I need to know more about the question now, so please don't write anything related to the topic. Thank you to everyone who wrote. Have a nice day.
    • It's an exhibition back so no access as you suggest.
    • I have no experience with this watch, but looking at the pictures from the ebay listing linked above, it looks like the outer metal bezel at the back of the watch may not be part of the case proper.  It looks like the watch and strap are sandwiched together, and an inner case may push out of the rear bezel towards the front of the watch.  A case style similar to the Roamer watches where the crystal, movement and caseback pushed out through the back of an outer bezel, only in reverse - this one may push out towards the front.  To test this, you would need to hold the watch, dial down, supporting the dial side of the watch around the edge of the bezel without touching the bezel itself. Then push down carefully on the inner metal ring you can see at the back of the watch. I’m speculating here, proceed at your own risk. Hopefully someone with hands on experience of these watches can chime in! Best Regards, Mark
    • Thanks, Mark. That's the kind of reassurance many of us wanted to hear! Yes, life is unfortunately unpredictable, and it would be a shame if the many dedicated WRT: ers became stranded if, god forbid, something happened to you and WRT stopped working.
