ETA 2824 dial feet do not match my Sellita SW200
sunday
Hello, I'm building a watch using a Sellita SW200 and I bought an ETA 2824 dial.  The dial has four feet and so does my movement, but they don't line up, the ones on the dial are too far apart relative to the movement.  I think if I cut off two feet I can make it fit but I'm not 100% sure.
Is this a common scenario?
Hi   Dial feet are usually specific to the movement but having said that there are dials and movements which are interchangable  some come with four feet attached to enable you to cut off the ones not needed.  When matching dials and movements it is wise to consult the tech sheets of both the movement and the movement of the donor dial to find compatibility.  e.g.  I have just replaced a miyota 2N50 (obsolete) with a Ronda 1032, the dial from the miyota fits with no modification, so research pays off  Alternativly you could use dial dots if there is no calendar work or re-solder the dial feet to suit the movement. There are machines on the market to do that or make your own. I did and it works a treat if there is no alternative.
the problem is your mixing chinese movement with a dial made for an eta which is also probably chinese. It most likely a fluke since eta 2824 is 100% a 4 feet dial. if you cant get it to fit by only cutting one then i would return the dial. You can always use adhesive dots but that may require you to use two dial spacers instead of 1.
Not sure? What the vernier caliper shows?
The OP has a Sellita which is Swiss made. Link to reference / casing information http://sellita.ch/scripts/calibres/images/Brochure_technique-SW200-1_39.pdf
As far as I know my Sellita is a legitimate Sellita as well, my dial came from Singapore, though.
I checked with calipers, and yes it looks like two feet match the distance.  I am not 100% sure that the orientation of the dial will be correct, though but it looks like: probably yes.
Based on the picture it looks like this Sellita only has 2 dial feet holes, those locations match up to the feet that I believe would fit my dial as well, if I cut the other two feet off.  I don't know if that is helpful.
It is helpful to you :)
The dial will hold perfectly with two feet.
Have a look at the thread below, it may help to answer your questions.
Incidentally, I've never come acros a dial that was mounted with 4 feet, and only occasionaly dials with 3 feet and they were big heavy enamelled pocket watch dials that maybe need 3 due to their weight.
  • Similar Content
    • HWGIKE#57 Valex FEF 190 15 jewels Swiss lever full service and repair This one was waiting for a balance staff replacement in my cabinet parts and case cleaned up with a new balance staff and a 4th wheel as the original 4th wheel had a broken pivot for the off center second hand. I never attempted a balance staff replacement before however I received a Bergeon Molfres (i was hunting it for about 2 years) and with the help of it I managed to remove the old staff and riveted the new one in. It also received a new MS, crystal and the hole for the MS arbor was also tightened. With the new MS now it has an acceptable performance meaning that the amplitude goes up to 280 fully wound, has an acceptable beat error and I have the two nice lines but only dial up, dial down is not as nice and I could not figure out as why. I have the two lines but the amplitude is dropping to around 230 and the lines are a bit hairy. Both dial up and dial down the lines just go up and down without seemingly any pattern. I cleaned the movement two times, and then a 3rd time pegged out the main plate and train bridge holes but made no change. Both the HS collet and the roller table was too lose on the new staff... I did not count how many times I took the balance cock off to sort out the HS collet, the roller table and the beat error, somebody before me also shortened the HS by pushing it out a bit and it seems every time somebody is messing with the end of the HS the protruding bit is most of the time twisted bent etc. This one was probably one of the most challenging repair and service. I might take the new MS out and clean it lubricate it as I just pushed the new one in to the barrel from the retaining ring. Plus started to re-read the theory of the escapement and how to analyse the graph on the timing machine: Greiner Chronografic Record manual. I am also thinking to put the watch on a 24 hour long run with the eTimer SW it once helped me to figure out what was wrong with a watch. There is an interesting part of the Greiner record manual talking about the pallets and the end shake of the balance and pallet staff. Maybe this is my issue? Who could that possibly identify? After a few years now I am still without a clue how could watchmakers make parts I can only see with my microscope or how could/can they carry out complicated services impossible to do.. real magic..... .... ..... before I sent this post while the pics were uploading I had an idea, i was browsing the possible outcomes on the timing machine I had one for magnetism..... so I demagnetized the movement and it is not hairy now.... two really nice lines 0.2 ms beat error still a bit wavy, but a lot lot better..... argh....
