   i am working on a watch that will run, but the wind is "locked up"   usually i find the click and let the spring down.   any ideas?   this watch has signs of being worked on.  vin
Not sure i am with you there? Is the ratchet wheel hidden so you can't unwind it? Like a citizen or Baumgartner 866. Pictures could help? Or movement?
44 minutes ago, watchweasol said:
Hi Vinn  any piccys or a calibre number?.
    i'll start with a picture,  a Navada,    i have the calibre, somw where.
Edited by vinn3
add info, mvmt may be val. 2346 - cal. 724
  the click (paul) is a rachet for the rachet wheel,  part of the mainsping barrel.  correct?  the watch will not run if the main spring is (up tight).    if you want to take the balance out. "let down the main spring".    this watch has the winding stem "locked up",    can not let the spring down. i want to avoid a total tear down of this valuable watch.  SO,   if i can find the click and release it,   a total tear down MAY be avoided.  are you with me now?    cheers,   vin
If it is a Baumgartner movement, they often hide the click under the main spring winding wheel with just a tiny tab to release the click.
Edited by FLwatchguy73
   thanks
On ‎12‎/‎9‎/‎2019 at 10:58 AM, nickelsilver said:
The click on a 72 is next to the column wheel, there's a pin sticking up through the bridge that you can hold to let down the power.
     good show.  thanks  vin
     the  click moves and is not under pressure.  so the bind is in the area of the spring barrel or the winding gears. needs tear down.  thanks for the help, ill put it away for a while.   vin
    • I have no experience with this watch, but looking at the pictures from the ebay listing linked above, it looks like the outer metal bezel at the back of the watch may not be part of the case proper.  It looks like the watch and strap are sandwiched together, and an inner case may push out of the rear bezel towards the front of the watch.  A case style similar to the Roamer watches where the crystal, movement and caseback pushed out through the back of an outer bezel, only in reverse - this one may push out towards the front.  To test this, you would need to hold the watch, dial down, supporting the dial side of the watch around the edge of the bezel without touching the bezel itself. Then push down carefully on the inner metal ring you can see at the back of the watch. I’m speculating here, proceed at your own risk. Hopefully someone with hands on experience of these watches can chime in! Best Regards, Mark
    • Thanks, Mark. That's the kind of reassurance many of us wanted to hear! Yes, life is unfortunately unpredictable, and it would be a shame if the many dedicated WRT: ers became stranded if, god forbid, something happened to you and WRT stopped working.
    • The case back is perfectly aligned to the case and has no provisions for a screwing tool. The T-Sport series has snap on backs.
    • For me the text looks too aligned and with no obvious way to grip as a screw back.
    • There’s no indents & there’s no little groove to pry it off anywhere! So I don’t know if it’s screw down or pry off 👍
