Hi everyone hope the holidays were joyful for all.
I am currently servicing an ETA 2824-2   and have hit a roadblock.  I need to put the watch in beat and the hairspring collet used is something I have not seen before.  Rather than a standard round collet or the V type this movement has a collet that resembles a four leaf clover and no slot.  I assume there is some special tool that can be used to adjust this but I have not been able to locate it.  My only other thought was to take an old stake and grind down the sides to make a tool.
Any advise would be most appreciated
Sincerely,
Jim
Found this on the net hope it helps
You can regulate a ETA 2824-2 by turning the eccentric screw (red arrow). For co**BLEEP**r regulation, you can shift the green arrow, but if you shift it noticeably, the rate changes significantly (so move it with caution). Do not touch the blue part as it changes the beat error, and you won't be able to correct it unless you have a Timegrapher.
Thank you for the advise.
I am using a timegrapher   the beat error is over 6   ms   and moving the blue arrow only gets me down to 4  the amplitude is also horrible    What I need to do is move the hairspring to get the watch at least close to in beat then I can fine tune with the blue arrow above.   But the collet holding the hairspring is not standard  so it appears a special tool is needed.   Just was hoping someone has put one of these in beat before   :-)
Sincerely
Jim
I presume at some stage the hairspring has been removed from the balance for a large out of beat error. If has not it might be worth checking that it is actually a beat error. Mark has a vid showing how to check this see below: If the hairspring has got to be moved someone for sure on this forum will have the answer.
Jaycey   Hey thanks for the post  I wish I knew if that was what I am looking for do you know if that fits 2824-2?
Thanks for the post  at least i am going in the correct direction.
Sincerely,
Jim
I presume at some stage the hairspring has been removed from the balance for a large out of beat error. If has not it might be worth checking that it is a beat error.Low amplitude can also be caused by damaged jewels or damaged balance staff. Mark has a vid showing how to check this see below: If the hairspring has got to be moved someone for sure on this forum will have the answer.
Sincerely,
Jim
Ahh I see, no that tool I linked to is not for that.
I am fairly convinced it is beat error typically ETA movements run low amplitude less than 200 new even the clone movements are higher, This one is in the 150 range  but I believe the amplitude is off because the beater error is so extreme.  I have played with this movement for a while now  lol  I feel confident if I can get it close everything will come into place.  I just need help with that collet.  Notice the nice slot in Marks video   BTW the watch was cleaned and serviced pivot ends are good jewels are fine.   Hope Mark chimes in  :D
Sincerely,
Jim
I have searched the net and could not find any specific tool for this style of stud. A stiff pair of brass tweezers might give enough purchase to move it but this can be risky so if it was me I would use the safest way possible and mark where it is positioned then remove the hairspring using the normal methods & re-fit to see if it improves or not.
Out of curiosity, in the diagram above, what does the arm that adjusts the beat error (marked with the blue arrow) actually act upon to make adjustments?
I think this is the tool   I was hoping Mark would be able to confirm    once I measure the diameter of the balance staff
Hoping
Jim
It's the anchor point for the end of the hairspring.
jaycey    The Blue arrow points to the stud end of the hairspring  as you move it one way or the other it changes the center point of where the balance roller jewel is striking.  This is the beat error adjustment as noted above.
Sincerely,
Jim
Sorry I didn't come on this thread sooner Jim, but it looks like you got a good result in the end.
What Geo posted was very helpful.   I bought an etachron tool  and ended up adjusting the regulator pins.  I found if they are not aligned correctly it also causes the watch to read out of beat.  Once I had those adjusted properly i was able to use the beat adjustment and affect a change.  I never did need to move the hairspring collet.
Thanks again everyone
Sincerely,
Jim
Sincerely,
Jim
That makes sense. Well done :)
    • Hi folks, I'm doing some homework on getting a watchmaker's lathe, and it's clear I have a lot to learn. But I know one goal: I want to be able to fabricate wheels, which would require an indexing capability. I know how to use large lathes- like, giant metal lathes- but my experience is a few decades old now (but you never forget the smell of the metal cutting oil). So I'm looking to learn anew, and have a goal to get to a point where I can fabricate some basic watch parts. I also have no specific timeframe and want to do this right, so I'll be patient and learn what I need to before spending the money. I know I'm not going to get anything for a pittance, but I'm also not really able to put together the scratch for a $5-$10k lathe. What's out there for a hobbyist that can either handle some fabrication out of the box or can be relatively easily made to do so? Thanks!
    • Hello and welcome to the WRT forum.   This usually points to broken balance pivot.  Though a watch in need of clean & lube can do the same. Easiest diag would be to  see if balance pivot doesn't stay in hole jewel of the setting, when you lift one side of balance rim with an oiler or gently with pair of tweezers. Another would be to detach balance complete from the cock and take a look at pivot under high maginfication.  Regs
    • Ahhh, yes.  I hadn’t thought of that.  I’ve serviced quite a few of these and the first time I didn’t realise it was a ships strike pattern!  Ha ha, confused me totally until I realised.
    • Hi Mike, I did, thanks. Found this clip that was really helpful:   It says Seth Thomas but it's actually the same Hermle I've been working on. I'd had it working correctly all along but hadn't noticed that the lever with the sprung end stops the hammer a bit short of the bell on the second ding at the end of the half-past sequence. If only I'd put the bell on when testing, rather than just looking at the hammer, my ears would have told me it was working,  even if my eyes didn't!
