I really like that.
Miyota movement so nothing to complain about the mechanics.
I really like the styling, especially the 24 hour numerals showing in the hour hand.
I think they are nice enough, and I almost pulled the trigger on a Marlin when they first came out. Decided I would stick with the originals, didn't need a reissue. Especially a $250 one.
Now, if they were $29.95 .....................
But perhaps about the price. Base Miyota is $45 retail, case dial and face worth $15 made in quantity. For the same price one can get much more value from a microbrand.
Another way of looking at it is building it yourself, the ultimate microbrand.
Cheapest Miyota movement at Cousins £36 (inc vat)
Cheapest diver style case on eBay £26 with no claim to water resistance
Dial & hand set £15
Decent leather strap £10
Total £87, you have to assemble it yourself which means that you have to buy some tools as well, and you have no effective warranties, particularly if the case leaks and destroys the movement, dial and hands.
This Timex works out at £170, has a 100m water resistance rating, and will have the manufacturers warranty and no need for any tools. I don't think that's too bad.
What microbrands are you referring to?
There is a new wave existing and growing in the last 5 years or so. I am no collector and I don't want to derail the topics so no precise pointers but all one has to do is to spend some time on Watchuseek, or searching "automatic" on Kickstarter.
I think this watch got various style elements right e.g. the hour hand windowing "military" time, rotating bezel, and of course being mechanical. These often determine the success more than others.
Edited by jdm
I guess you pays your money and you takes your choice.
I still like the Timex though, and even though you can pay less for similar (or even better) specs, Vostok Amphibia for instance, I don't think the price is too bad.
Or £229 if you buy it from the Timex UK site (but it is currently out of stock).
A bit of a cheek charging more in the UK than Canada, but then again we should be used to that. Most US items arrived with a pound per dollar price in the UK.
I have be honest I didn't check Timex UK, and like you say @AndyHull it's a bit cheeky stinging us Brits a premium price. At £229 it's pushing the outer limits of reasonable and entering into much more competetive territory, I guess best option is to buy it from Canada if it's what you want.
And be charged 20% + handling fees at Customs. Prices are lower in the USA (no VAT) and Canada (10% ?) exactly because of that.
Edited by jdm
    • I have no experience with this watch, but looking at the pictures from the ebay listing linked above, it looks like the outer metal bezel at the back of the watch may not be part of the case proper.  It looks like the watch and strap are sandwiched together, and an inner case may push out of the rear bezel towards the front of the watch.  A case style similar to the Roamer watches where the crystal, movement and caseback pushed out through the back of an outer bezel, only in reverse - this one may push out towards the front.  To test this, you would need to hold the watch, dial down, supporting the dial side of the watch around the edge of the bezel without touching the bezel itself. Then push down carefully on the inner metal ring you can see at the back of the watch. I’m speculating here, proceed at your own risk. Hopefully someone with hands on experience of these watches can chime in! Best Regards, Mark
    • Thanks, Mark. That's the kind of reassurance many of us wanted to hear! Yes, life is unfortunately unpredictable, and it would be a shame if the many dedicated WRT: ers became stranded if, god forbid, something happened to you and WRT stopped working.
    • The case back is perfectly aligned to the case and has no provisions for a screwing tool. The T-Sport series has snap on backs.
    • For me the text looks too aligned and with no obvious way to grip as a screw back.
    • There’s no indents & there’s no little groove to pry it off anywhere! So I don’t know if it’s screw down or pry off 👍
