Bobb
Bobb
Hello!  I know this is a watch forum, but I believe that clock questions are also welcomed, so based on that, I hope that someone can point me in the right direction, on my question :
I have a wall clock ( not old - about 30 yrs ) which has a battery powered clock 'movement' . It has a powered pendulum and two different  1/4 hour  & hour chimes ( one is the Westminster chime ) which can be selected. Anyhow, the clock is of no antique value (obviously ) but is of sentimental value. For the past few months, the hands don't turn ( or do so, now and again, randomly ) and unless they cross the 15 min. / hour marks, there is no chime. The pendulum however continues doing it's thing. Now this clock was not expensive or of any big name and the hands / chime is a small  box / battery holder. I have looked online for a replacement, and have seen some very similar looking ones, but they don't have the chime ability ( electronic chime / speaker ) . I wonder if anyone knows if such a replacement unit is available, or what the search term is for it,  and where I might look for one?  Any help would be greatly appreciated. Thanks in advance.
Hi Bobb,
Welcome to the group..
I had a quick look on ebay, this one turned up. If you are going to keep for sentimental reasons, look where this movement is there are cheap chime clocks, maybe cobble one up from one..
https://www.ebay.co.uk/itm/Seiko-Quartz-Strike-Chime-Clock-Movement-Euro-Shaft-16-5-mm-Speaker-68-x82/264563944209?hash=item3d993d6b11:g:WE0AAOSw5PJbElgL
Also there are a lot of members on here that might know  other sources..
Good luck Len
Hi Len and thanks for the swift reply! That appears to be the sort of thing I am looking for. as yet, I haven't taken the clock apart to actually see what the unit physically looks like, but it might me repairable, but TBH, I would imagine it is case of simply replace the whole unit. In the mean time, I'll leave this post parked here, and if someone swings by that has run across the same item. I will post some pictures, when I actually strip it down. In the mean time, thanks for the help!
Depending where you are based it may be better to buy from a wholesaler such as Cousin here in the U.K, you say the clock is fitted with a pendulum so you will need a movement with a drive unit built in for the pendulum. As far as repair goes clock repairers would not waste time trying to they would just do a straight swap out of the movement, you need to identify the movement fitted cousins have Hermle and Seiko versions available:
https://www.cousinsuk.com/product/strike-chime-with-pendulum-hermle
https://www.cousinsuk.com/product/strike-chime-with-pendulum-seiko
Also bare in mind that you would need one with the correct shaft size.
    • HWGIKE#57 Valex FEF 190 15 jewels Swiss lever full service and repair This one was waiting for a balance staff replacement in my cabinet parts and case cleaned up with a new balance staff and a 4th wheel as the original 4th wheel had a broken pivot for the off center second hand. I never attempted a balance staff replacement before however I received a Bergeon Molfres (i was hunting it for about 2 years) and with the help of it I managed to remove the old staff and riveted the new one in. It also received a new MS, crystal and the hole for the MS arbor was also tightened. With the new MS now it has an acceptable performance meaning that the amplitude goes up to 280 fully wound, has an acceptable beat error and I have the two nice lines but only dial up, dial down is not as nice and I could not figure out as why. I have the two lines but the amplitude is dropping to around 230 and the lines are a bit hairy. Both dial up and dial down the lines just go up and down without seemingly any pattern. I cleaned the movement two times, and then a 3rd time pegged out the main plate and train bridge holes but made no change. Both the HS collet and the roller table was too lose on the new staff... I did not count how many times I took the balance cock off to sort out the HS collet, the roller table and the beat error, somebody before me also shortened the HS by pushing it out a bit and it seems every time somebody is messing with the end of the HS the protruding bit is most of the time twisted bent etc. This one was probably one of the most challenging repair and service. I might take the new MS out and clean it lubricate it as I just pushed the new one in to the barrel from the retaining ring. Plus started to re-read the theory of the escapement and how to analyse the graph on the timing machine: Greiner Chronografic Record manual. I am also thinking to put the watch on a 24 hour long run with the eTimer SW it once helped me to figure out what was wrong with a watch. There is an interesting part of the Greiner record manual talking about the pallets and the end shake of the balance and pallet staff. Maybe this is my issue? Who could that possibly identify? After a few years now I am still without a clue how could watchmakers make parts I can only see with my microscope or how could/can they carry out complicated services impossible to do.. real magic..... .... ..... before I sent this post while the pics were uploading I had an idea, i was browsing the possible outcomes on the timing machine I had one for magnetism..... so I demagnetized the movement and it is not hairy now.... two really nice lines 0.2 ms beat error still a bit wavy, but a lot lot better..... argh....
