A couple of years ago I traded a nice Seiko hereby seen by its B-side
Today I got on my hands on this one:
just two numbers apart, of the many made that same year and month.
This had an amplitude of "just" 220° after few seconds from full wind. That wasn't enough for me today, so I tried the so called mini service which is cleaning and oiling the balance and pallet only. It reacted very badly to this questionable practice, dropping amplitude to less than 180°, although always with a clean pattern. Then while reinserting the stem I managed to snap a teeth off a plastic corrector wheel. Oh well, calendar off, main bridge off, there was a short fiber sitting on the seconds wheel or thereabout.. all parts bathed in hexane (that's yet another name for petroleum ether), rinse in distilled water, rinse in IPA, all is scrumptiously cleaned and lubricated, now an end stone suddenly disappears... To the spares tray again.. everything back together and Bob's your uncle at 270° amp. and perfect pattern.
So what about the lost cap jewel? I had searched for some time with day light, but it must have camouflaged good on my cherry wood desk bench, so I went on with reassembling. Then at dark I took a so-called UV mini-light all over the place, it took 30 seconds to see it shining in full fluo :biggrin:
Edited by jdm
Been thinking of buying myself one of those UV flashlights.
Question: do you see any practical use for it ? Would you be able to spot metallic parts as well ? Can you look at various parts with it and see flaws ? Maybe the dial ?
At Euro 2 is not a purchase one has much to mull about. Some uses, examine banknotes, spot leakages in air/oil/water pipes after adding fluorescent liquid, there are more for sure.
I picked one up a while back, like the image above. It is a neat toy for all sorts of other uses too. Banknotes, looking at rocks to see what minerals glow, checking out ancient lume to see where the flakes of low level radioactive  waste are lurking in the case, curing UV cure epoxy. Well worth the not very much, shipped and delivered from China that I paid for it.
I'll need to remember your trick the next time I inevitably drop a jewel on the carpet. I suspect if I looked there today, it would probably sparkle like a Christmas tree with all the stuff that is lurking in the pile.
Sadly metal objects will not glow, but lots of plastic and ceramic parts do.
Edited by AndyHull
Just been looking at latest Moebeus lube chart and see that they are marketing fluorescent versions of some of their oils.  Maybe use one of these lights to see where the oil is (or not as the case may be!).  A flown part with oil on may also show up?
All the best to one and all.
    • I have no experience with this watch, but looking at the pictures from the ebay listing linked above, it looks like the outer metal bezel at the back of the watch may not be part of the case proper.  It looks like the watch and strap are sandwiched together, and an inner case may push out of the rear bezel towards the front of the watch.  A case style similar to the Roamer watches where the crystal, movement and caseback pushed out through the back of an outer bezel, only in reverse - this one may push out towards the front.  To test this, you would need to hold the watch, dial down, supporting the dial side of the watch around the edge of the bezel without touching the bezel itself. Then push down carefully on the inner metal ring you can see at the back of the watch. I’m speculating here, proceed at your own risk. Hopefully someone with hands on experience of these watches can chime in! Best Regards, Mark
    • Thanks, Mark. That's the kind of reassurance many of us wanted to hear! Yes, life is unfortunately unpredictable, and it would be a shame if the many dedicated WRT: ers became stranded if, god forbid, something happened to you and WRT stopped working.
    • The case back is perfectly aligned to the case and has no provisions for a screwing tool. The T-Sport series has snap on backs.
    • For me the text looks too aligned and with no obvious way to grip as a screw back.
    • There’s no indents & there’s no little groove to pry it off anywhere! So I don’t know if it’s screw down or pry off 👍
