Hello,
I have ordered a robur glass press and dies (expensive) and my first project is to change the mineral glass of my nephew's watch. However, when I watched Mark's videos on changing glass he used a flat die but as far as I can tell there are no flat dies in the robur die set. My question is if I can still use the press with the supplied dies or use some sort of plate between the die and the glass without breaking anything, neither the watch nor the die ?
Why an expensive tool and set when there so many affordable one that work perfectly.
You can use a crowned die. Place some plastic in between the crystal to avoid marring it.
Edited by jdm
