I have a few Camy watches and couldn't resist this Camy 'Silver Cloud' on ebay despite its non running description (it was cheap, £11 inc p&p:P)
On arrival it was soon obvious that the movement was the old faithful FHF96 and balance spring was FUBAR'd:thumbsd:
I had a quick check around and found that I could get a new balance but couldn't justify paying the £30+ on this watch.
What I did find though that I could buy a 'good running' FHF96 equipped, re-cased and dialled 'Oris' from India for £13 inc p&p....
Well the 'Mumbai Special' arrived and I was suitably surprised with the obviously totally rebuilt movement in it (probably a new Indian built copy)
Not wanting to 'sully' the Camy with this movement, I settled for just swapping over the balance assemblies. I fitted the Camy with a nice new genuine alligator strap from Vietnam and the result is one nicely running vintage Camy and lots of FHF96 spares, total outlay, including the new strap, less than £35 including all carriage costs:D
Did that with a Seiko diver that I once bought but came with a movement in a very bad shape. Managed to find a cheap Seiko 5 with the same movement...
I wish I could do the same for really old watches as I just managed to break the arbor on a wheel of a watch I was working on and I can't even find parts. (and they'd be pricey if I did)
Did something similar with this Seiko 7548-700F (Stormin' Norman)...
Rebuilt the movement using a 7546 dress watch movement as the basis...(one of these days I'll probably fit the original movement bridge back, to get the jewel count, at five, correct again..)
And cleaned the dial as  best I could and replaced the hands and bezel insert with OEM Seiko SKX 007 parts...
I find resurrecting basket cases very satisfying:thumbsu:
    • I have no experience with this watch, but looking at the pictures from the ebay listing linked above, it looks like the outer metal bezel at the back of the watch may not be part of the case proper.  It looks like the watch and strap are sandwiched together, and an inner case may push out of the rear bezel towards the front of the watch.  A case style similar to the Roamer watches where the crystal, movement and caseback pushed out through the back of an outer bezel, only in reverse - this one may push out towards the front.  To test this, you would need to hold the watch, dial down, supporting the dial side of the watch around the edge of the bezel without touching the bezel itself. Then push down carefully on the inner metal ring you can see at the back of the watch. I’m speculating here, proceed at your own risk. Hopefully someone with hands on experience of these watches can chime in! Best Regards, Mark
    • Thanks, Mark. That's the kind of reassurance many of us wanted to hear! Yes, life is unfortunately unpredictable, and it would be a shame if the many dedicated WRT: ers became stranded if, god forbid, something happened to you and WRT stopped working.
    • The case back is perfectly aligned to the case and has no provisions for a screwing tool. The T-Sport series has snap on backs.
    • For me the text looks too aligned and with no obvious way to grip as a screw back.
    • There’s no indents & there’s no little groove to pry it off anywhere! So I don’t know if it’s screw down or pry off 👍
