Hi Nickelsilver,
Your knowledge of horology has never seized to amaze me.
We are lucky to have access to you through this forum.
Thank you for staying tuned with us.
Best wishes.
  • Like 7
    • No mate. Sorry if that offends you! Also please don’t take threads off-topic. I thank you sir.
    • Thanks Mark I have uBlock Origin Lite add-on for my Windows Chrome browser, so I've never seen a single ad on this site ! It also removes all adds from Youtube - I couldn't bear to watch it without uBlock
