How to get to the movement on this Tissot?
While I did order a 955.112, I also ordered a coil for the 715. The coil came in first and I replaced it today. Tada! Functioning again. I still plan on doing the swap, but will likely wait to see what watches come in my grandfather's collection, and what needs work. This was my first fix outside battery or strap changes. Pic of new coil to compare to the old coil above. Old battery just to test, silver oxide 371 is in it now.
The different numbers are a clue to the lathe being a collection of parts although saying that some manufacturers said that any parts they made would all fit each other part within tolerance
Due to the age of this post it would appear the server where they're stored has started dumping photos to make space.
Only ever seen them as part of a case.
