Hi all,  Seller claims it is in good running condition, obviously can use a good clean and needs few screws.
Is dial paint original?
How about parts availability? What kind of budget for parts do you think I should appropriate?
Your opinion please, never had a universal.
Would need more and better photos.
At first glance that looks like a redial. Crown is a replacement ? Seems slightly different in color than the case and possibly bigger than what it should be. What about the hands ? Wouldn't be surprised if those are non-genuine either.
I don't know the movement so can't tell about that one. Seems alright but we'd need to compare it to others...
The case clamps are installed wrong. They should go inside the case so to speak which is actually a retaining ring that can come out with the whole movement I believe.
Edited by Chopin
By coincidence I have one of these lovely watches with me at this time. It was almost running but after opening it - which took all the power of the bench opener-- it doesn't anymore?!? Waiting to know if the owner will accept my modest estimate for service.
Now for the value aspect, I don't really know first hand, but for a realistic estimate I would check chrono24 and subtract 20% from the asking price of the better comparable piece.
    • I have no experience with this watch, but looking at the pictures from the ebay listing linked above, it looks like the outer metal bezel at the back of the watch may not be part of the case proper.  It looks like the watch and strap are sandwiched together, and an inner case may push out of the rear bezel towards the front of the watch.  A case style similar to the Roamer watches where the crystal, movement and caseback pushed out through the back of an outer bezel, only in reverse - this one may push out towards the front.  To test this, you would need to hold the watch, dial down, supporting the dial side of the watch around the edge of the bezel without touching the bezel itself. Then push down carefully on the inner metal ring you can see at the back of the watch. I’m speculating here, proceed at your own risk. Hopefully someone with hands on experience of these watches can chime in! Best Regards, Mark
    • Thanks, Mark. That's the kind of reassurance many of us wanted to hear! Yes, life is unfortunately unpredictable, and it would be a shame if the many dedicated WRT: ers became stranded if, god forbid, something happened to you and WRT stopped working.
    • The case back is perfectly aligned to the case and has no provisions for a screwing tool. The T-Sport series has snap on backs.
    • For me the text looks too aligned and with no obvious way to grip as a screw back.
    • There’s no indents & there’s no little groove to pry it off anywhere! So I don’t know if it’s screw down or pry off 👍
