Dear readers, I have a Seiko Lassale watch with movement 6020a which is very dear to me but beyond repair. I cannot find a new or good running used 6020a and also no replacement watch that fits the housing. I hope that there is someone that can help me.
thanks a lot,
best regards,
Walter Jansen,
amsterdam Holland.
Thanks for the link, is it not important that there is an A at the end of the 6020 number? The 6020a is 2,1mm thick with battery and the movement size is 24,6mm. Casing diameter 24mm. I have no knowledge of movements of Caliber and want to go to a watch repair place with a replacement 6020a for my watch.
I think you could use a Seiko 7N00, which is easily available. A case ring should be made or adapted, and for an economical repair the dial may be held with adhesive pads.
Edited by jdm
Thank you very much for the usefull tip. I will search for more info about dimensions of the Seiko 7N00 and try to find a watch repair shop to do this special job..
thanks again and best regards,
walter Jansen.
