Hi all,
Just wanted to say hello (a newbie to this forum). I got started with this new hobby in November, took Mark's course levels1 and 2, plus the TimeZone course, levels 1 and 2, and am hooked. Fortunately I live near Otto Frei making getting parts, supplies, and tools a breeze. I look forward to participating with you all in this horological journey.
Best,
DanB
    • Hi watchweasol, yes that is a way of doing it I suppose, I have a pair of mainspring hole making pliers on their way off eBay, the ones with the different shaped punches. I may be able to use them to make a hook.
    • Hello everyone, Glad to be here.
    • No mate. Sorry if that offends you! Also please don’t take threads off-topic. I thank you sir.
