This Vid explains how the Seiko spring drive works. Seiko IMO are now the leading innovators of the industry. This is a truly new concept giving a mechanical watch the accuracy of quartz.
I like Seiko a lot. But it must be noted that Spring Drive is partly quartz, because that is the timing element used to precisely brake a wheel. And it's not even that new, having started sales in 1999.
To be fair, with just that to boast in 3 or 4 (if you count developing time) decades, Seiko is not a major of a technology innovator when it comes to mechanical watches. The title should perhaps go to Omega with Coaxial escapemnt, Rolex and others with silicon hsirspings, and the Swiss and German industry at large, the only ones that have introduce many totally new movements. Not to mention their haute horlogerie which never cease to amaze with incredible realizations.
Very informative! I thought these were quartz driven but are in fact a main spring driven but quartz regulated. I wonder, did anyone ever service one of these Spring Drive watches? I wouldn't mind wearing that GS! :biggrin:
I don't think that any member here did. Seiko mandates these to be sent to Japan for repair or service. Because of that you can find tons of marketing material, influencer and owner raving but very little in-depth technical covering. The Horological Times issue attached below has some. And I remember a photo service by an American watch academy, but can't find it anymore.
2006-01-web.pdf
I wouldn't mind pulling one to pieces :chainsaw:
Neither would I, if I was in a Seiko workshop and guaranteed immunity.
Not terribly expensive starting €2,000 for an used one, still no good reason for an amateur to take chances on it.
u are right jdm but wouldn't it be nice to have the ability and confidence :cigar:
    as i recall.   the early "de Carle" book says the concept of a slipping main spring was patended by Movato.  vin
  • Confused 1
    VERY good refural !
Hi  yes they did , I was Trevor Bayliss who invented it ostensibly for the third world  where they did not have electricty or access to batteries. I have one in the workshop. There is a handle at the back which folds out and than you crank it up It works quite well.
I got a spring drive and expect more power reserve for the money or of the technology. The speed power reserve builds up in it was interesting back when I bought the piece and have ever since wondered about its precision after repair.
Has anybody seen a serviced one?
This has gone off piste a bit. The reason this is an innovative concept is the achilles heal with the mechanical watch has always been the escape. The most errors, faults and time discrepancies are the escape and this eliminates these errors. The purists will reject this and claim it only quartz but it is a mechanical watch but quartz driven. For now with a $47,000 price tag many will not purchase but as time progresses the costs will drop and it will become a real alternative for consideration.
Please explain yourself better? What is the current power reserve, and why you do worry about precision after repair, which can only be done throught officical channels at Seiko Japan for a an high price certainly?
You have been here a long time and I'm sure you know well the ins and outs of this forum. We are lucky to have very knowledgeable people about Swiss and non-Swiss piece of moderate to medium value, plus a Master Watchmaker. But when it's about an elitist's Japan Domestic Market piece , you would struggle finding a repair expert worldwide, outside of Seiko.
By the way I'm myself amazed about the lack of knowledge about Japanese/Seiko top end offering. As in confusing Spring Drive with Kinetic / AGS (Automatic Generatic System), etc. Grand Seiko / Spring Drive has been a pinnacle produce very well know to demanding watch collector since at least a decade.
Few purists except perhaps the most hardheaded ones reject the value of Spring Drive / Grand Seiko watches, just have a look at the "inventory signatures" of prominent collectors on popular sites like WatchUSeek.
Luckily for prospective buyers as I mentioned above the the entry price to the club is Euro 2,500 for 2nd wrist nice piece and not exceedingly more for a brand new one:
https://www.seiyajapan.com/collections/grand-seiko/products/grand-seiko-spring-drive-gmt-sbge213
That is just to show a listed price of JPY 669,600, (about EUR 5,800), before considering discounts and manufacturer  restrictions.
    • The ones I have opened also do not have a pry point , hence the reason for the tool. The watch is clamped in the tool and a blade is screwed into the seam, the blade being chamfered lifts the back then the screw shaft is turned and the back comes off have a look on Ali express for case back removal tools
    • I don't think I need to know more about the question now, so please don't write anything related to the topic. Thank you to everyone who wrote. Have a nice day.
    • It's an exhibition back so no access as you suggest.
    • I have no experience with this watch, but looking at the pictures from the ebay listing linked above, it looks like the outer metal bezel at the back of the watch may not be part of the case proper.  It looks like the watch and strap are sandwiched together, and an inner case may push out of the rear bezel towards the front of the watch.  A case style similar to the Roamer watches where the crystal, movement and caseback pushed out through the back of an outer bezel, only in reverse - this one may push out towards the front.  To test this, you would need to hold the watch, dial down, supporting the dial side of the watch around the edge of the bezel without touching the bezel itself. Then push down carefully on the inner metal ring you can see at the back of the watch. I’m speculating here, proceed at your own risk. Hopefully someone with hands on experience of these watches can chime in! Best Regards, Mark
    • Thanks, Mark. That's the kind of reassurance many of us wanted to hear! Yes, life is unfortunately unpredictable, and it would be a shame if the many dedicated WRT: ers became stranded if, god forbid, something happened to you and WRT stopped working.
