Greetings to All Members:
Just found your website today & decided to join. From what I saw on your home page looks like you carry a broad range of topics. I have been collecting watches about 2 years.  Always on the lookout for mainly wrist watches, both mechanical & electronic.......and occasionally quartz. Have no real specific brand other than mostly American Names from the 20's through 1960's. I also have several mantle clocks & several pocket watches. Just always on the lookout for any interesting examples of particular eras. I have limited skills & "eye sight" outside of working on case, dial , hands & crystal polishing/replacement.
Currently am working on a Timex Dynabeat(ElectroMechanical).....I hope your site has some people that work on these Timex Dynabeat Watches....purchased on EBay.....looks good after clean & polish but not running. Battery leaked some but not too bad......just want to remove works from case to clean leaked corrosion. But on this watch I am at a lose as to how to remove the stem from watch works.......any information or vidios on this would be appreciated.
Thank you.    Dan
..any information or videos would be appreciated
Hi if you remove the movement from the front by removing the crystal (front loader) then you have a split stem .pull the stem out to the time setting position
carefully place a pair of tweezers under the crown and gently pull evenly and the stem will pull in two pieces. Then you can place the watch on a movement pad and tip it upside down and it will separate from the  case .Make sure that you pull evenly with the tweezers .
Edited by Graziano
I don't think that is quite right.:startle: See here:-
You use the tweezers to expand the retaining spring to release the stem.....In practice you usually have to do this twice as the very end part of the stem usually catches on the retaining spring and stops you pulling it all,of the way out......
Edited by JohnD
Oh my I apologize thank you:o
Never the less --- by puting the tweezer tapers under the crown AND apply gental pressure is a good way TO FIND OUT if the watch has a 2 part stem OR NOT.   the diagram told you a timex has a special to get the mvt. out of the case.   this is the best forum for learning, videos and books,    cheers.    vin
The OP was asking about that particular Timex electronic calibre.....
