Correct method for increasing end-shake.
Very surprising if you need them all? What is the issue you’re seeing? Tom
I forgot to upload the picture. These are the kind of watch jewelry I'm looking for.
The ones I have opened also do not have a pry point , hence the reason for the tool. The watch is clamped in the tool and a blade is screwed into the seam, the blade being chamfered lifts the back then the screw shaft is turned and the back comes off have a look on Ali express for case back removal tools
