Hi. I have a Tommy Hilfiger watch that damaged the pusher a few months ago when it fell on the ground.
I opened the watch to try to fix the pusher because it is stuck in a pressed position. I tried pushing it back from the inside after removing the mechanism but it is very hard. I was going to try using a press to remove it but I don't know if the pusher is pressed or it is threaded.
The inside is just a pin with a circular lock.
How can I find this out?
For a watch of that value I assume that it's pressed in. From my past experience the likely reason for the pusher holding in is that the shaft is bent and preventing it from move moving smoothly in the pusher housing. Before looking to replace the pusher, I would press the shaft from inside the watch case to reset the pusher position and then check the angle of the pusher head. The circlip could be removed to release it entirely for examining the bent shaft and straightening it. I've even left a pusher assembled and grasped the pusher button and straightened it. I'm currently wearing a Speedmaster automatic Day-date that I corrected this way and it didn't affect water resistance.
Good luck!
Sent from my BBF100-2 using Tapatalk
  • 6 months later...
Thanks Lwayslate.
I saw your message back then. but I only could manage to remove it today. It was oxidized but all rust was removed.
Now the issue is the reason it was stuck: the housing for the button is just a little bent. Probably due to a fall. The button is perfect
What would be the best technique to unbent it? i can't think of any tools i have that would fit there.
Its stainless steel. So very hard...
Thanks for the update, that's great news!
When you get the chance please post a photo of the the watch once it's reassembled.
There it is. One last thing: how to deal with the broken circular plastic holder? Any good glue to fix or better a replacement? Can't think a place to get it.
Those holders are brittle plastic. I’d just leave the broken bit out and put it back together.
Did you lube/replace the gaskets? Last thing you want is water washing your hands...
hi tudor.
doing so the button would be useless, as if i had not fixed it.
I used silicone spray to lubrificate the rubber. the other button is working better than before. I also have a habit to avoid watches come near to water :)
Oh, so the pusher acts on the plastic?!? That’s different.
I guess I’d try one of the flexible cyanoacrylate glues designed for plastic. Or maybe a soldering iron could “weld” the plastic.
    • Like these? https://www.watch-tools.de/metal-straps/springbars/assortment-360-strong-spring-bars-beco-inox-o-1-8mm.php
    • I've seen them on several swiss-made movements as well. Last one was a Tissot if I remember correctly.
    • This thread might be interesting for you:
    • I've never seen them, then again, I haven't got a ton of experience, but "common"? Really? In what context have you seen them? I'm not questioning you. I am sincerely curious why I've missed it. An alternative to Fixodrop is to apply less oil (no more than 50 % of the circle area). The only downside would be that it would shorten the service interval. More oil will prolong the service interval, but if the movement is subjected to trauma, there's a risk it will be displaced. Fixodrop makes it more stable. Unfortunately, Fixodrop is seriously expensive.
