L & R Maxomatic Ultrasonic
JerseyMo
Has anyone here worked on an ultrasonic such as this one?  L&R Maxomatic..
I was told it will smoke when powered up. After opening it up I pulled the tube and right away I see it failed because the top cap fell off!
Also I noticed debris inside which of course is not a good sign either.
So what to do?  I found a used tube for BIN at $20.00 and best guess is the machine is maybe worth $40.00 Is it something I should get into just for the fun of it?
Heck yeah, what is the worst I can be other than burning down the house :)
As long as your competent with mains electricity wiring and your doing it just for yourself, go for it.
I don't know what the electrical laws are in the USA, but in Australia you would actually need a restricted electrical lenience to work on something like that.
A valve driven ultrasonic cleaner, that a first on me, I didn't even know they had been making them for that long.
Hi  Guys  I have an international ultrasonic valve driven  the machine works ok but the ultrasonic does not, Bought as a project several years ago still waiting to be done. I will post some pics sometime..  As JerseyMo's one is a single valve, get stuck in and have a go, It might make a big bang so power it up in the yard.:D
I was told the machine was made in 1975 but did not verify that.  No matter as I did go ahead and order a replacement tube. Someone else advised to replace any electrolytic caps. But, there are only two disk caps inside.
I am assuming 'valve' is the same as 'tube'?
License?  Sure I got one of those!
forgot to mention - you see the maker is located in Kearney NJ.  that is just a few miles from where I picked this machine up.
Edited by JerseyMo
20 hours ago, luiazazrambo said:
If this is the same as yours ( nawcc ) the schematic might help you. If there is smoke there is a reason for that and you probably have to eliminate that otherwise you will end up replacing parts in an endless loop.
Thanks, I came across that data sheet as well. The tube replacement will be as far as this repair attempt will go.
Hi   here are a few pics of my ultrasonic bought some years ago as aproject, got to get it done.
Its a british made National ultrasonic watch cleaner, It all works,motor,heater. The ultrasonic is dead and there is no life in the Valve(tube)  812A  Amplifier so the clean up begins an then I shall get a valve for it..
What was the one you got JerseyMo, was it the same an 812A,?...
Yes, I found a 812A on ebay.
43 minutes ago, watchweasol said:
Hi JerseyMo     I dont know if you have the schematic for the L&R machine.  I found this whilst researching my national, Its not over good but better than nothing  if you are without.       Cheers
Thanks,  the cleaner will be going back to work at my watchmakers shop. He had given it to me for an 'AS IS' sale on ebay. but of course I could not resist to take it apart and figure out why it was not working.  I should have told him it was just 'over wound'  and needed a servicing.   :)
Nicely done.
Yes Valve and tube are the same thing, I still find it amazing that we can all be talking the same language and sometimes still not know what each other means. due to georgraphic variations of some words.:D
The one that creates the greatest confusion between Australia and the UK is the little rubber 'shoe' you put on your feet.
In the USA I think you call it a 'flip flop' in the NZ they are called Jandles (No idea why), in Australia we call them 'thongs' which I know in the UK and I think the USA is skimpy bathers which in AUstralia are called G-strings.
You can imagine the looks I got when I first went to the UK and told people that in the summer in Australia it was generally too hot to wear shoes and so I would usually just wear my 'thongs' :D
according to Urban Dictionary
After a japanese swimming team came to NZ (many decades ago), one observer was so impressed with their style of footwear that he began making them himself - he came up with the word "Jandal" as an abbreviation of the term "Japanese Sandal"
  • 5 years later...
33 minutes ago, AndyGSi said:
Then i expect it would be an earth to the case back.
Thanks for the help. I don't see anywhere where it would connect to the case back, although I do see perhaps a spot on the oscillator/vibrator that based on the bend and length of the wire, I suspect it may go. The same connected wire goes up to one side of the body of the oscillator/vibrator, so perhaps this one is also supposed to be connected to it. Let me know what you think.
On 4/4/2025 at 3:43 PM, AndyGSi said:
Looks a good call to me, just the question is how was it bonded.
Seems like it was just stuck into the epoxy. Would I be able to reattach it at another point on the body of the oscillator, or do you think that there is a specific terminal covered by that epoxy that I must connect it to.
    • HWGIKE#57 Valex FEF 190 15 jewels Swiss lever full service and repair This one was waiting for a balance staff replacement in my cabinet parts and case cleaned up with a new balance staff and a 4th wheel as the original 4th wheel had a broken pivot for the off center second hand. I never attempted a balance staff replacement before however I received a Bergeon Molfres (i was hunting it for about 2 years) and with the help of it I managed to remove the old staff and riveted the new one in. It also received a new MS, crystal and the hole for the MS arbor was also tightened. With the new MS now it has an acceptable performance meaning that the amplitude goes up to 280 fully wound, has an acceptable beat error and I have the two nice lines but only dial up, dial down is not as nice and I could not figure out as why. I have the two lines but the amplitude is dropping to around 230 and the lines are a bit hairy. Both dial up and dial down the lines just go up and down without seemingly any pattern. I cleaned the movement two times, and then a 3rd time pegged out the main plate and train bridge holes but made no change. Both the HS collet and the roller table was too lose on the new staff... I did not count how many times I took the balance cock off to sort out the HS collet, the roller table and the beat error, somebody before me also shortened the HS by pushing it out a bit and it seems every time somebody is messing with the end of the HS the protruding bit is most of the time twisted bent etc. This one was probably one of the most challenging repair and service. I might take the new MS out and clean it lubricate it as I just pushed the new one in to the barrel from the retaining ring. Plus started to re-read the theory of the escapement and how to analyse the graph on the timing machine: Greiner Chronografic Record manual. I am also thinking to put the watch on a 24 hour long run with the eTimer SW it once helped me to figure out what was wrong with a watch. There is an interesting part of the Greiner record manual talking about the pallets and the end shake of the balance and pallet staff. Maybe this is my issue? Who could that possibly identify? After a few years now I am still without a clue how could watchmakers make parts I can only see with my microscope or how could/can they carry out complicated services impossible to do.. real magic..... .... ..... before I sent this post while the pics were uploading I had an idea, i was browsing the possible outcomes on the timing machine I had one for magnetism..... so I demagnetized the movement and it is not hairy now.... two really nice lines 0.2 ms beat error still a bit wavy, but a lot lot better..... argh....
